Block imperfections - anything to worry about? #751626 09/14/06 03:10 AM
Cory_dup1 Offline OP
Hi all
I'm in the process of doing a head gasket replacement on my 1990 4ZE1, as some of you may recall from previous posts. Due to other obligations I haven't worked on it for a while, but I am back at it again now.
Once I got the old head gasket cleaned off the block, I noticed 2 small divots in the surface of the block right at the top edge of cylinder #4, where my head gasket failed...I believe they were created when the metal ring on the head gasket broke, as they are located at the very location the gasket failed. They are just big enough to snag a fingernail or razorblade. The divots should be visible in the following photos at the top edge of the cylinder, just underneath the left half of the large water jacket hole. The water jacket IÆm referring to is to the right of the guide pin in the pictures.
Pic1: [Linked Image]
Pic2:[Linked Image]
So my question is, am I likely to need a new head gasket in the near term if I donÆt have the surface of the block milled...or the cylinder bore widened? I donÆt know if these imperfections are big enough to worry about or not? I donÆt fancy going through the whole process of replacing things if I will just be doing the same again in 5 or 10 thousand miles due to these divots in the block. Just looking for some advice here, as I have no experience when it comes to this û beyond knowing that the surfaces ôshouldö be totally flat. Thanks for any guidance or advice you can give!
Re: Block imperfections - anything to worry about? [Re: Cory_dup1] #751627 09/14/06 03:24 AM
Richard Saylor Offline
Personally, if there is any imperfections in the sealing surfaces, I would get them machined. The gasket might be able to compensate and fill the void, but I would not trust it.
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: Block imperfections - anything to worry about? [Re: Cory_dup1] #751628 09/14/06 04:14 AM
trooperbc Offline
show these photos to a couple of *good* machine shops and get their advice. and judge their responses.
1992 sohc trooper 3.2l v6 automatic . . . as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Re: Block imperfections - anything to worry about? [Re: Cory_dup1] #751629 09/14/06 09:15 AM
Madcat Offline
is it me or does the piston look damaged in the 2nd pic?
Madcat <img src="/forums/images/graemlins/kewl.gif" alt="" />
1979 Pontiac Trans-Am - looking 4 a pontiac 455cid
1988 Trooper II - AMC head, .030 overbore, Calmini cam. Toga HV oil pump, Aisins, soon 2 b turbo
1989 Impulse Turbo - Fidanza flywheel, 270cc injectors, turbo-back exhaust, KYBs F/R
Re: Block imperfections - anything to worry about? [Re: Madcat] #751630 09/14/06 05:07 PM
It looks like the piston has some damage, the cylinder walls have some damage and the deck has some damage to me. If that is the case, then it is either time for a new block, or it is time to get this one bored out and the deck milled.
84 Honda XL185S
Re: Block imperfections - anything to worry about? [Re: Richard Saylor] #751631 09/14/06 05:20 PM
Gizzy42 Offline
Yes the piston has some damage. But, in the Previous Post it was suggested to just run it as is.
As far as the ridge. I personally would probably just leave it that way, but then I'm like that <img src="/forums/images/graemlins/notooth.gif" alt="" /> Showing the pics to a good machine shop is a good suggestion.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO on US Wheel 94 series
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 50 series SUV 2.25"
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Re: Block imperfections - anything to worry about? [Re: Gizzy42] #751632 09/15/06 07:19 AM
NATO308 Offline
Get a ridge reamer and clean it up, should be all that is needed. Also replace that piston or you will be doing something to the engine again shortly.
'94, and '00 Amigos and '00, 01 Rodeos. Rodeo springs and aftermarket 'hard top on 94. Aisin hubs OME 919's on the 2000 Amigo. 2000 and 2001 Rodeos have OME 912's and Aisin. Smoother ride with the OME 919's???
Re: Block imperfections - anything to worry about? [Re: Gizzy42] #751633 09/15/06 10:33 PM
Troopersphere Offline
It's kinda hard to tell how big that missing piece really is. In the old pics, it didn't look all that bad. And, those vertical marks on the cylinder wall didn't show up at all. Are those scores into the metal ?
I dunno, it's hard to judge from the pics... but personally, I would try to "get away with it" ... I've gotten away with worse things. How much money you wanna throw at that truck ? That should be one of the deciding factors...
C/YA!
Jeff
'88 Trooper
2DR LWB 4ZE1 5SP
bone stock DD
Re: Block imperfections - anything to worry about? [Re: Cory_dup1] #751634 09/18/06 02:22 AM
Thanks for the advice everyone! That's a good idea to show the pics to a machine shop...I will try to do that next week.
Nato, I have never used a ridge reamer before, but it seems that using one of those to get rid of the "dent" would result in the entire edge of the head gasket sticking out around the top of the cylinder a little....which seems like it could lead to more problems? I could be off base though, since I have never used one and am not that familiar with how they work.
Troopersphere, those marks you were asking about are not scratches in the metal...I think it was a result of the coolant leaking in and causing some discoloration. When I run my finger over the area it is perfectly smooth. In regards to my last post, you had asked if my rear-most exhaust manifold stud was broken...it was! Just an FYI I forgot to mention to you. Thanks again for the advice everybody...if anyone else has ideas I'd love to hear them! <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6317 MB (Peak: 0.7372 MB) Data Comp: Off Server Time: 2026-06-10 01:35:49 UTC
