FUEL FILTER #751715 09/14/06 05:07 AM
Neo Offline OP
Anyone tried to replace the fuel filter yet? My replacement from NAPA says I have to use the manual pump - my Dodge has one. Anyone found it on a 4D56? Other tips on this job? <img src="/forums/images/graemlins/cheers.gif" alt="" />
1991 JDM SWB Pajero TD - Sold....
1997 Dodge Ram 2500 Cummins 4x4
Re: FUEL FILTER [Re: Neo] #751716 09/14/06 06:18 AM
redbull Offline
I remember a great post on POCUK about this with pics. Try a search over there if nobody here can answer.
Re: FUEL FILTER [Re: redbull] #751717 09/15/06 12:09 AM
Jonno Offline
are you looking for the location of the manual pump or how to bleed the system?
Re: FUEL FILTER [Re: Jonno] #751718 09/15/06 06:18 AM
Neo Offline OP
I found an article on the procedure on pocuk - thanks for the idea. I am looking, still, for the manual pump if it exists - the bleeding directions (no pun intended) were clear from the pocuk article.
Re: FUEL FILTER [Re: Neo] #751719 09/15/06 04:40 PM
Jonno Offline
on mine, 91 exceed, if you move the intercooler out of the way and look at the top of the fuel filter unit. A white plastic bolt/knob should be on the left hand side. That is the manual pump. it unscrews and works like a plunger when the air or water bleed is opened. hope this helps
Re: FUEL FILTER [Re: Jonno] #751720 09/15/06 05:31 PM
Bernoulli Offline
Thant's how I remember it on my 88 import.
89 3L V6 5spd SWB, Aisin Manual Hubs, 2 (suspension) seater Raider in Wheeler, OR
Re: FUEL FILTER [Re: Bernoulli] #751721 09/20/06 04:23 AM
Neo Offline OP
Did the job today - I have no mechanical experience and it took me just under 1 hour, had to remove one of the batteries to get at the filter. I think I may have overtightened the thingies that hold the fuel lines onto the other thingy that the filter screws onto... <img src="/forums/images/graemlins/scared.gif" alt="" /> Truck started immediately after with no apparent adverse effects of the process. <img src="/forums/images/graemlins/kewl.gif" alt="" />
OT - put a Clarion deck in yesterday, too!
Re: FUEL FILTER [Re: Neo] #751722 09/20/06 07:41 PM
Macka Offline
I know on the big trucks we tighten them hand tight, then 1/4 turn for snugness. I also prime my filters to 3/4 full before installing them. This saves a lot of time under the pump when the filters hold 2 litres of fuel.
always working
Re: FUEL FILTER [Re: Neo] #751723 09/22/06 04:18 AM
PHIL_ Offline
Did my filter last weekend also. Where'd you get yours, Neo? Mine was a crappy tire item. I pulled the intercooler instead of the battery. Not sure which would give better access, but maybe next time I'll try the batt, and see?
P
Re: FUEL FILTER [Re: PHIL_] #751724 09/22/06 06:34 AM
Neo Offline OP
Got mine from NAPA - about $39. Access was fine just pulling the battery - I wanted them disconnected anyway before I started spilling fuel. <img src="/forums/images/graemlins/scared.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6371 MB (Peak: 0.7611 MB) Data Comp: Off Server Time: 2026-06-10 01:37:45 UTC
