QuadraCrap? #751866 09/15/06 03:33 AM
I have a 1976 Jeep CJ7 with the 304 V8, TH400, and QuadraTrac transfer case. I need to have the transmission rebuilt and was considering swapping the transfer case. I don't do any major rock climbing but I do take it on some pretty rough trails. Right now it is pretty much all original. In the future I want to lift it enough to accommodate 33" tires. Does anyone know if there is a different transfer case that will work with the TH400 that wouldn't take a lot of modification or could anyone offer any ideas for a tranny/tcase swap that wouldn't be outrageously priced?
76cj7joe
Re: QuadraCrap? #751867 09/15/06 04:10 AM
valleycat Offline
dana 18. if you want to swap out the rear end to one that has a centered diff, the dana 20 and dana 300 are good swaps.
i'm not sure how a center output t-case would work with your offset rear end. it might work though.
Re: QuadraCrap? [Re: valleycat] #751868 09/15/06 05:20 AM
cuervo25 Offline
the cj 7 had off set rears too? i knew the chorokees and wagoneers did,but i thought the cj had center diff rears.
Re: QuadraCrap? #751869 09/15/06 06:49 AM
BobRowe Offline
Is your QuardaTrac misbehaving at present? If not, I'd suggest keeping it, as long as you don't intend to do any heavy duty rock climbing. Granted, the QuadraTrac isn't nearly as strong as a Dana 20 or a Dana 300 t-case, but I've seen plenty of them work fine as long as they are serviced properly and not overly abused.
All CJ7 differentials are offset to at least a small degree. I have a Dana 300 transfer case, which is considered a centered rear output. And yet, the differential in the AMC 20 rear axle is slightly offset -- by that, i mean that the two axle shafts are different lengths.
CJ7 axles that were mated with a QuardaTrac T-case are even more offset, clearly to the point where it is observable without measuring.
Re: QuadraCrap? [Re: cuervo25] #751870 09/15/06 04:37 PM
valleycat Offline
most are but the q-tracs are different because the rear output is offset like the dana 18.
Re: QuadraCrap? [Re: BobRowe] #751871 09/16/06 07:18 PM
[quote]Is your QuardaTrac misbehaving at present? If not, I'd suggest keeping it, as long as you don't intend to do any heavy duty rock climbing. Granted, the QuadraTrac isn't nearly as strong as a Dana 20 or a Dana 300 t-case, but I've seen plenty of them work fine as long as they are serviced properly and not overly abused.
I've been hearing a grinding sound up front which leads me to believe that the chain may be stretched. I guess I could replace the chain. I guess what I'm wondering is how the costs would compare for rebuilding the tranny/t-case I have now and for changing them both out.
Re: QuadraCrap? #751872 09/21/06 04:44 AM
Thumpszilla Offline
Is this the bw1339 Quadratrac? I have one in my jeep and just rebuilt it with new chain and all new seals from bj's offroad for $135.
FrankenJeep J-10
80 body and frame
77 258 engine
79 th400 and bw1339
79 d44's with 3:54gears welded rear
36" Iroks on 15x10 rockcrawlers
Soa and shackleflip
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6112 MB (Peak: 0.6892 MB) Data Comp: Off Server Time: 2026-11-18 22:47:06 UTC
