Check engine light comes on at highway speeds #752000 09/15/06 10:38 PM
swamprunner Offline OP
For some reason I can't figure out my check engine light comes on at highway speeds around 65mph. It comes on for a couple of minutes then goes off. Then it will come back on after a few mintes and then go off again. This only occurs at highway speed not driving around town. The motor is a 22re with the a stock turbo. I've searched the forum but can't find anything. I'm not to worried about it just wondering if anybody else has had this problem or any ideas of what might be causing this.
85 SR5 4runner....Too many hours of work put into it, Hacked, Beaten, and Still running after all I've put it through
87 Turbo Pickup...Bought Her for $500 put another $500 in her and she's running like a dream.
Re: Check engine light comes on at highway speeds [Re: swamprunner] #752001 09/16/06 05:43 AM
Davepet Offline
Pull the trouble codes from the computer. It should record whatever is causing the light to come on.
Re: Check engine light comes on at highway speeds [Re: Davepet] #752002 09/16/06 06:26 AM
willzrunna96 Offline
id say its most likely an o2 sensor..
Re: Check engine light comes on at highway speeds [Re: willzrunna96] #752003 09/16/06 04:46 PM
4x4runner Offline
My guess would be TPS. Mine has been doing that same thing and I just readjusted my TPS and all is well again. Where in NC are you?
Re: Check engine light comes on at highway speeds [Re: 4x4runner] #752004 09/18/06 03:24 PM
ToyotaT Offline
When mine did that I think it was the O2 sensor.
85 Toy Pickup
89 block 30 over and EB RV head/261 cam
Re: Check engine light comes on at highway speeds [Re: 4x4runner] #752005 09/19/06 08:55 PM
Well it shouldn't be the o2 sensor b/c it is new. It might be the tps but its running fine and I don't know if I want to mess with it. Never pulled the codes before. Guess I'll have to look in the manual and see what it has to say. Or maybe I'll just take the bulb out and forget about it.
4x4runner...I'm on the outer banks... are you out west?
Re: Check engine light comes on at highway speeds [Re: swamprunner] #752006 09/19/06 09:23 PM
4Crawler Offline
Re: Check engine light comes on at highway speeds [Re: 4Crawler] #752007 09/20/06 12:19 AM
4x4runner Offline
My truck also ran great but mpg was off, TPS was out of adjustment. I live in Winston Salem.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6222 MB (Peak: 0.7039 MB) Data Comp: Off Server Time: 2026-05-30 03:47:07 UTC
