Check engine light comes on at highway speeds
#752000
09/15/06 10:38 PM
For some reason I can't figure out my check engine light comes on at highway speeds around 65mph. It comes on for a couple of minutes then goes off. Then it will come back on after a few mintes and then go off again. This only occurs at highway speed not driving around town. The motor is a 22re with the a stock turbo. I've searched the forum but can't find anything. I'm not to worried about it just wondering if anybody else has had this problem or any ideas of what might be causing this.
85 SR5 4runner....Too many hours of work put into it, Hacked, Beaten, and Still running after all I've put it through
87 Turbo Pickup...Bought Her for $500 put another $500 in her and she's running like a dream.
Re: Check engine light comes on at highway speeds
[Re: swamprunner]
#752001
09/16/06 05:43 AM
Pull the trouble codes from the computer. It should record whatever is causing the light to come on.
[Re: Davepet]
#752002
09/16/06 06:26 AM
id say its most likely an o2 sensor..
91 pickup 5.29's US GEAR.35x 12.50 trxus m/t.5 speed swap- SOLD! 96 4Runna limited-toytec/OME lift,diff drop Nitto 285/75/16 Elocked=butter 07 FJ cruiser 3" DR coilovers 285/75/16 nitto TG. allpro sliders
[Re: willzrunna96]
#752003
09/16/06 04:46 PM
My guess would be TPS. Mine has been doing that same thing and I just readjusted my TPS and all is well again. Where in NC are you?
[Re: 4x4runner]
#752004
09/18/06 03:24 PM
When mine did that I think it was the O2 sensor.
85 Toy Pickup 89 block 30 over and EB RV head/261 cam
[Re: 4x4runner]
#752005
09/19/06 08:55 PM
Well it shouldn't be the o2 sensor b/c it is new. It might be the tps but its running fine and I don't know if I want to mess with it. Never pulled the codes before. Guess I'll have to look in the manual and see what it has to say. Or maybe I'll just take the bulb out and forget about it.
4x4runner...I'm on the outer banks... are you out west?
[Re: swamprunner]
#752006
09/19/06 09:23 PM
[Re: 4Crawler]
#752007
09/20/06 12:19 AM
My truck also ran great but mpg was off, TPS was out of adjustment. I live in Winston Salem.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6227 MB (Peak: 0.7045 MB) Data Comp: Off Server Time: 2026-10-30 10:19:57 UTCValid HTML 5 and Valid CSS
