help #752008 09/16/06 01:41 AM
Roll_me_over Offline OP
ok here's the situatuion. When I'm driving after the motor warms up I'll be going and then nothing. It doesn;t "miss" or die but it has no power and the more you push the pedal down, the more it slows down. If you let off the gas and wait a second and give it a little gas it will kinda start going again. It acts funny. Once it starts doing this, I can pull over and let it sit for a minute and then it will start and drive normally for a while and then do it again. Maybe fuel pump? what the hell is going on???
02 Ford F-250 4X4 PSD...zero body damage
67 Weimann 18' Jet boat...zero body damage except for the trailer drags on the ground from time to time
Re: help [Re: Roll_me_over] #752009 09/16/06 01:55 AM
FrankR Offline
Check all of the vacuum lines - then try changing the fuel filter. If that doesn't fix it, rebuild the carburetor.
Frank
Re: help [Re: FrankR] #752010 09/16/06 05:44 AM
man you are one smart cookie there Frank...fuel filter was clogged up and there was a vacuum line that broke. Fix it and she runs like new... <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: help [Re: Roll_me_over] #752011 09/16/06 11:57 AM
FrankR Offline
Ask any tech or service writer - a good description of the issues (like you gave) makes diagnosis a lot easier. Glad it's fixed. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Frank
Re: help [Re: FrankR] #752012 09/17/06 01:11 AM
Yeah it was something simple like I figured. I picked up a new fuel pump and filter before I posted about it. Just wanted a second opinion on it. I occasionally have brain farts so I wanted to make sure I was on the right track...
Thanks Frank <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6070 MB (Peak: 0.6715 MB) Data Comp: Off Server Time: 2026-05-29 18:49:13 UTC
