holy moly torsion bolt snapped #752519 09/18/06 09:39 PM
willzrunna96 Offline OP
talk about a very scary feeling the adjusting bolt for the torsoin bar snaped and felt like my truck droped 3ft. good thing is i ordered a new one from the dealer today but gotta wait 2 days for it. anyone else have this happen. also is there anything i need to know as far as installing the bolt again. i guess i just tighten it up untill both sides are equal off the ground?
Re: holy moly torsion bolt snapped [Re: willzrunna96] #752520 09/18/06 10:12 PM
Jake97T Offline
lots of antiseize, a company that sounds like les schwab broke mine, might look for a hole in the floor where the torsion arm may have pierced the cab...
Re: holy moly torsion bolt snapped [Re: Jake97T] #752521 09/19/06 02:12 AM
Scerb Offline
you're lucky. I know of two people around here that have broken fingers when the same thing happened..
Re: holy moly torsion bolt snapped [Re: Scerb] #752522 09/19/06 03:19 AM
yes i know i had 2 cigarettes and 2 beers after that one <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: holy moly torsion bolt snapped [Re: willzrunna96] #752523 09/19/06 05:09 AM
ChrisH Offline
i was laying on my back under the front diff when mine snapped the one time.
buddy of mine was torquing on it and i guess i trusted him a little too much when he said he didn't really need the weight off the tire (like i recommended)
thank god im not any bigger or i may have ruptured something! the crossmember came to rest right on my pelvis and hip bones. i coulda lost some very substantial things if it had fallin even another inch or too. <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" />
scary #@%*
glad you didn't ahve any disasters come of it.
'95 Toyota Pickup DX Xtended Cab ~ Daily Driver
Re: holy moly torsion bolt snapped [Re: ChrisH] #752524 09/19/06 06:08 AM
Jake97T Offline
same reason mine broke, tire shop didnt take the load off the front before adjusting...funny cuaz they charged me for the bolts...
Re: holy moly torsion bolt snapped [Re: Jake97T] #752525 09/19/06 08:42 AM
W
Whatever Offline
Mine broke on the driver's side once and I was in the Burger King drive thru. I was just handing the chick my money and "KAPOW", just like you said it felt like my truck fell 3 feet. I just looked at the chick and said the only thing I could think of...."That's not good"....she laughed....I did not...lol.
Re: holy moly torsion bolt snapped [Re: willzrunna96] #752526 09/19/06 09:16 AM
Brian894X4 Offline
I had an after market A-arm snap in two, at the end of a trail...but that's another story.
I have had my adjusting bolts snap on me as I was trying to undo them. I think that's pretty common. The bolts have really long nuts on them with lots of threads, so once they corrode or get junk on the threads, and you try to back them out, they get locked tight and when undoing them something has to give and usually you end up twisting the bolt until it breaks, thinking that your just undoing a really tight nut.
Obviously, you should never try adjusting the bolts with weight on the truck, since they are then supporting half the truck's weight. I'm sure a few bolts have broke because of this, but mostly its because of the really long nuts and threads that lock the bolt tight when they get corroded and/or dirty.
As for breaking just sitting in a drivethrough or parked somewhere, the only explaination I have for that is that the bolt was probably already twisted and weaked from previously attempts to loosen it or tighten it. There is absolutely no reason that a stock bolt should ever just break for no reason while your driving or parked, even if they are old and original, in my opinion.
Re: holy moly torsion bolt snapped [Re: Brian894X4] #752527 09/19/06 11:46 AM
ChrisH Offline
totally agree with brian, they are very prone to having the threads get marred up easily with corrosion or dirt and the like.
For the same reason I've noticed when adjusting mine that they get VERY hot which can't help keep them in one piece either
Re: holy moly torsion bolt snapped [Re: ChrisH] #752528 09/19/06 08:56 PM
half_fast Offline
These bolts break all the time...specially when over torqued or not cleaned before adjusting.
Michael J. Carsner proud driver of "Aint Pretty"
37 boggers, 571 gears, Detroit+Lock-Rights, 20R stage 1 LC Engineering head on 22R motor.
MUD!!! Its whats for dinner!!
PHP: 7.4.33 Page Time: 0.015s Queries: 16 (0.011s) Memory: 0.6416 MB (Peak: 0.7656 MB) Data Comp: Off Server Time: 2026-11-17 11:19:17 UTC
