1986 22rec, I need lots of advice. #752572 09/19/06 02:11 AM
Mikeweb Offline OP
I am in the middle stages of replacing a timing chain. I have pulled the head, and my intake and exhaust valves are pretty crudded up. My mechanic friends have recommended replacement. Does anyone know where I can get a kit or set to replace everything that won't break the bank? I also need to get the head machined. So, I was wondering if anyone knows if I could find a new head with the valves preassembled, and if so how much?
The other thing I'm wondering about is a good way to clean out the intake manifold, throttle body, and everything in between. The whole assembly is just caked with crudd. Any suggestions?
Re: 1986 22rec, I need lots of advice. [Re: Mikeweb] #752573 09/19/06 02:47 AM
1
1986xtracab Offline
www.engnbldr.com very good stuff.
Re: 1986 22rec, I need lots of advice. [Re: 1986xtracab] #752574 09/19/06 02:51 AM
4Crawler Offline
Find a shop that will throw it in their hot tank or I used a small parts washer (tub with solvent pump) and let the solvent run though each runner for a day or so then brushed out the soften gunk. Oven cleaner is also supposed to work well, although may discolor the aluminum.
Re: 1986 22rec, I need lots of advice. [Re: Mikeweb] #752575 09/19/06 02:53 AM
Mikeweb Offline OP
I almost forgot. Is it ok to rebuild the top side of the engine without doing anything for the lower half? I am trying to keep it stock. I don't want to do anything special with the valve rebuild.
Re: 1986 22rec, I need lots of advice. [Re: Mikeweb] #752576 09/19/06 03:20 AM
4Crawler Offline
That is what I did on mine. Bottom half was in fairly decent shape, maybe 3 years on a rebuilt block.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6077 MB (Peak: 0.6722 MB) Data Comp: Off Server Time: 2026-06-17 13:43:18 UTC
