Adjusting rear pinion angle on a Gen II 4Runner #752652 09/19/06 05:46 AM
StealthTJ Offline OP
How are y'all adjusting the rear pinion angle on the Gen II 4Runners ?
I haven't seen a single ad for adjustable rear upper control arms for 'em.
I've seen control arms but they are stock length with JJ's on rod ends on them to loosen the rear up a little
Surely with any amount of lift the working angles on the u-joints (rear driveshaft) are out of spec., especially those of you running 4" (or more) of suspension lift.
I suspect that a couble cardon (CV) joint rear driveshaft is required, but to use that the pinion needs to be adjusted upwards.
smile
Fred
Re: Adjusting rear pinion angle on a Gen II 4Runner [Re: StealthTJ] #752653 09/19/06 07:59 PM
ldivinag Offline
you can get adjustable arms from downey.
all pro has them too:
http://allprooffroad.com/index.php?option=content&task=view&id=45
leo d.
90 4runner, v6, auto, WCOR CitB kit,
marlin duals, arb rear, tt front
4.88, blah, blah, blah...
Pres. of TEAM IFS! and
GETTING OFF 4WD Club member
Re: Adjusting rear pinion angle on a Gen II 4Runner [Re: ldivinag] #752654 09/25/06 04:34 AM
J94_4runner Offline
I put Leafs on the rear of my '94. I have 3" AP's with the axle pushed back about 1-2". I wish I had gone with a longer leaf... like the chevy's. and I adjusted everything with the stuff "tacked" in place. then welded.
another option would be to just make your own custom JJ HD arms and brackets. that's probly not a bad idea....
www.celicasupra.com
PHP: 7.4.33 Page Time: 0.016s Queries: 15 (0.013s) Memory: 0.5940 MB (Peak: 0.6475 MB) Data Comp: Off Server Time: 2026-11-19 05:33:58 UTC
