I need sunroof Help. 91 Pajero
#752762
09/19/06 06:12 PM
Well GUYS it was supposed to be a surprise but I need help before I post pictures..
Purchased a RH drive, SWB 3.0 Pajero. Auto. Sunroof, R/D lock. Air Suspension etc.
BUT
Moonroof was stuck shut due to summer heating. When i tried to open it *crack* internal spiral cog has busted teeth on the bottom now.
Mitsu dealer has no part numbers, all VINs pull up LWB sliding roofs. 4 hours wasted at the dealer today.
Can anyone help with a part number etc?
It is the moonroof with the Rotating cap in the cab , the roof ONLY raises 6 inches. IE Does not slide. Currently the wheel spins either way with no lifting of the roof.
SO
If a UK or Asian member can give a part number for the internal cog..or a VIN number from USA/ Europe for a vehicle that has the rising moonroof maybe that will help.
Thanks!
91 SWB V6 Raider. (Japan) R/H Drive. Rear Lock. 32x11.5 BFG A/Ts w/ 15x8 rims 1000 watt Kenwood amp w/ 2 10"JBLs
Re: I need sunroof Help. 91 Pajero
[Re: 4X4_Canuck]
#752763
09/25/06 01:05 AM
[Re: 4X4_Canuck]
#752764
09/25/06 01:20 AM
Drew, get me a pic of the part you're referring to, and I'll see if a part number exists for it. But even with a part number, your dealer will look at you like you have nine heads. Trust me.
BTW, hows the lip that surrounds the glass holding up on yours? Mine is deteriorated and needs replacement, so I'm also looking for a North American equivalent so I can grab the rubber lip.
Phil
[Re: PHIL_]
#752765
09/25/06 01:25 AM
Hey Phil ! That rubber is shot on mine too. I will get a pic of the part, i will take either the part ( hope that's the prob ) or the entire assembly if need be. On th up side, the place on Van Island that is importing these trucks has said they are going to be purchasing parts vehicles for us. So maybe that will help. I can give u the number if you want. Loving the new TOY haha 3.0 V6, Rear diff lock, air susp ( i think ) with 3 settings + 3 inch lift in the rear selectable. [img][image] http://i10.tinypic.com/4ideh4i.jpg[/img][/image]
[Re: 4X4_Canuck]
#752766
09/25/06 01:36 AM
Also working on trying to get the crank bolt covered under the Safety bulletin.
They can't understand why the VIN doesnt come up ( DUH it's a new BC VIN ) And it has gone to mitsu Canada. The vehicle is a 91 ( not covered ) but the SB covers engines 01/91+ so we'll see
<img src="/forums/images/graemlins/confused.gif" alt="" />
[Re: 4X4_Canuck]
#752767
09/25/06 02:12 AM
I cant help you with the sun roof. Post pics of said vehicle. Just buy the bolt, something like $3. In cab selectable lift?
[Re: sparkem]
#752768
09/25/06 02:37 AM
I cant help you with the sun roof. Post pics of said vehicle. Just buy the bolt, something like $3. In cab selectable lift? It's not a bolt, but a 3 inch cylindrical piece with screw like threads from top to bottom. Star shaped plastic teeth on the bottom ( which are now broken ) Yes, in cab selectable lift. -4x4
[Re: 4X4_Canuck]
#752769
09/25/06 03:04 AM
I guess we posted at the same time. Awesome truck, gen1 LS rims. <img src="/forums/images/graemlins/smile.gif" alt="" /> It's not a bolt, but a 3 inch cylindrical piece with screw like threads from top to bottom. Star shaped plastic teeth on the bottom ( which are now broken )
For a 3.0? Do you have a pic? I got updated crank bolts for mine, but I dont know about a star plastic thing.
[Re: sparkem]
#752770
09/25/06 03:11 AM
For a 3.0? Do you have a pic? I got updated crank bolts for mine, but I dont know about a star plastic thing. I think the star thing is for his sun roof...
73 -Jon KJ6GVM As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter Grampa's Trooper 1974 FJ40 1987 FJ60
[Re: Oyaji_Jon]
#752771
09/25/06 06:19 AM
D'OH, I was thinking crank bolt as in Crank shaft pulley bolt some 3.0s had a recall on.
You might want to check into that too.
