Changing diff fluid on a 97 LS #752812 09/19/06 06:53 PM
TeaQue Offline OP
What kind of fluid should I use?
Are there any tips one would like to share? <img src="/forums/images/graemlins/smile.gif" alt="" />
1997 Montero LS
3.5 V6
31x10.5 BFG A/T's
T-bar lift
Optima Yellow Top
Cheap Pilot Fog lights
Re: Changing diff fluid on a 97 LS [Re: TeaQue] #752813 09/20/06 01:07 AM
Scottie2113 Offline
As long as you don't have the LSD, just use 90W gear oil, various types of brands and blends.
97 Montero SR w/Mitsu Adj Shocks & Rear Diff Lock ARB Front Diff Lock 4.9 Ring/Pinion 3.15 transfer box 43:1 crawl ratio 2" suspen lift 2" body lift 2" Gas Tank Lift 35x12.5 MTRs 15x10 Wheels Rock Sliderz ARB front bumper w/12k winch Custom rear bumper
Re: Changing diff fluid on a 97 LS [Re: Scottie2113] #752814 09/20/06 01:25 AM
sparkem Offline
Make sure you can get the fill plug off before you pull the drain plug. You dont want to figure out you cant fill it back after it is empty.
Re: Changing diff fluid on a 97 LS [Re: sparkem] #752815 09/20/06 01:37 AM
TeaQue Offline OP
How do I know if I have LSD?
I thought it only came on SR models? <img src="/forums/images/graemlins/confused.gif" alt="" />
1997 Montero LS
3.5 V6
31x10.5 BFG A/T's
T-bar lift
Optima Yellow Top
Re: Changing diff fluid on a 97 LS [Re: TeaQue] #752816 09/20/06 01:55 AM
LandRaider Offline
SR models had lockers.
Orange sticker on the drivers doorjamb will tell you if it is LSD
Re: Changing diff fluid on a 97 LS [Re: LandRaider] #752817 09/20/06 02:26 AM
sparkem Offline
Your LS should have an open diff.
Re: Changing diff fluid on a 97 LS [Re: LandRaider] #752818 09/20/06 02:27 AM
TeaQue Offline OP
Ok just looked. Assuming it would have been somewhere next to the VIN number---there was no orange sticker anywhere.
What kind of fluid do you guys recommend?
1997 Montero LS
3.5 V6
31x10.5 BFG A/T's
T-bar lift
Optima Yellow Top
Re: Changing diff fluid on a 97 LS [Re: TeaQue] #752819 09/20/06 03:01 AM
LandRaider Offline
Gear oil. Any brand is fine.
The sticklers will want the Specific dodge Hypoid stuff.
Re: Changing diff fluid on a 97 LS [Re: TeaQue] #752820 09/20/06 03:10 AM
jaco Offline
i used red line's 75w90 gear oil on mine. it is compatible with both open and limited differentials. you can get it for around $8/quart.
Re: Changing diff fluid on a 97 LS [Re: LandRaider] #752821 09/20/06 03:10 AM
TeaQue Offline OP
Good.
I was hoping I could just run to Autozone and do this in the next day or two <img src="/forums/images/graemlins/notooth.gif" alt="" />
Any clue as to how much I'll need?
Thanks a lot everyone!
1997 Montero LS
3.5 V6
31x10.5 BFG A/T's
T-bar lift
Optima Yellow Top
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.007s) Memory: 0.6394 MB (Peak: 0.7459 MB) Data Comp: Off Server Time: 2026-11-16 01:17:11 UTC
