Re: Changing diff fluid on a 97 LS [Re: TeaQue] #752822 09/20/06 04:34 AM
sparkem Offline
Somewhere around 2.5 quarts, your manual should tell you exactly. Fill until it comes out of the fill hole and put the bolt back in. Easy job.
Re: Changing diff fluid on a 97 LS [Re: sparkem] #752823 09/20/06 03:31 PM
W
Winston Offline
It should be 2.7 for the rear diff and 1.3 for the front. Which comes out to exactly 4 qts. You might as well do both while you are under there. Then again, why not do your transfer case (2.4 qts) and your transmission (about 4 qts)? You should do all of those fluids every 30k miles.
'90 Montero XLS (Sold, sadly)
'95 Montero LS 160k
'03 Montero Limited 30k
Re: Changing diff fluid on a 97 LS [Re: LandRaider] #752824 09/21/06 01:53 PM
koolaid6666 Offline
Orange sticker on the drivers doorjamb will tell you if it is LSD
On a 97 The Sticker would be On The Driver's side Center Console towards The Floor. <img src="/forums/images/graemlins/kewl.gif" alt="" />
2003 Montero Limited White
2001 Montero GLS Diesel
1990 Montero Black Off Road Package.
1990 Montero Parts Truck.
Re: Changing diff fluid on a 97 LS [Re: Winston] #752825 09/22/06 03:52 PM
TeaQue Offline OP
Ok, I'm going to try to tackle this if I have time today.
How do I do the transfer case? Are there any filters I need to replace?
I just need gear oil correct?
I had my tranny fluid changed about 10k miles ago so I just need to do the front/rear diff and transfer case.
1997 Montero LS
3.5 V6
31x10.5 BFG A/T's
T-bar lift
Optima Yellow Top
Cheap Pilot Fog lights
Re: Changing diff fluid on a 97 LS [Re: TeaQue] #752826 09/22/06 05:57 PM
sparkem Offline
The transfer case will have a drain plug and a fill plug just like the diffs. I am not sure if the gen2 with the 4Hi mode needs something special. Check your manual. With the t case, it is hard to reach the fill hole with just the bottle of fluid. They make a flexable tube that screws onto the gear oil bottle that you can get up to the fill hole easier. There are also a few pumps you can buy to pump the fluid up to the fill hole. Also make sure you use the correct size socket and/or wrench, you dont want to round the plug off. I use a 15/16s or a 24mm. If you run into any problems, post up.
PHP: 7.4.33 Page Time: 0.014s Queries: 16 (0.011s) Memory: 0.6133 MB (Peak: 0.6939 MB) Data Comp: Off Server Time: 2026-11-17 11:17:17 UTC
