Replace lifters or replace engine? Why pay $1800 for lifters when.... #753024 09/20/06 10:45 PM
bbusbee Offline OP
The lifters in my wife's 97 Trooper are making noise at 135k miles. I have changed the oil every 3k miles consistantly but the noisey lifters come and go. The dealership wants close to $2000 (cost of parts only) to replace all of them and I guess there are 24, and other automotive places can't get them. Where can I buy replacements at a reasonable price and or would it be better to just spend that 2k towards the cost of a replacement remanufactured engine?
Re: Replace lifters or replace engine? Why pay $1800 for lifters when.... [Re: bbusbee] #753025 09/20/06 11:42 PM
litnin Offline
Send Jerry Lemond an email. He has the lifters and
will do you much better than any dealer.
jlemond@bellsouth.net
1995 Trooper LS auto 3.2 DOHC /w SOHC intake
1989 Trooper 2.6 auto
1989 I-Mark RS DOHC 1.6
1991 Stylus XS DOHC 1.8
Re: Replace lifters or replace engine? Why pay $1800 for lifters when.... [Re: litnin] #753026 09/22/06 08:35 PM
Bigpoppax2 Offline
Do that or do what most people do....
Nothing. It's not really hurting anything. Just listen to the ticking 3.2 Isuzu engine and drive on down the road.
Joe
Re: Replace lifters or replace engine? Why pay $1800 for lifters when.... [Re: Bigpoppax2] #753027 09/24/06 09:28 AM
Strider93 Offline
Others have gone through and had their lifters (properly called Hydraulic Lash Adjusters, or HLAs) replaced, only to have the new ones start ticking after a couple of thousand miles. Its a crap shoot.
I think you should go through the AutoRx route first...
My ticking HLA's tell me when its time to change the oil <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Replace lifters or replace engine? Why pay $1800 for lifters when.... [Re: Strider93] #753028 11/02/06 07:43 PM
bbusbee Offline OP
I have done quite a bit of research and found that the probable cause could be clogged lubrication holes in the valve train that are fairly small. I tried a lighter weight oil and after several thousand miles the tapping is making it's come back now. <img src="/forums/images/graemlins/confused.gif" alt="" />
This is a question for all, if the problem truly is caused by poor lubrication from very small holes that get clogged easily, why wouldn't it be possible to open up the holes a bit? Exactly which holes would be causing the problem?
Re: Replace lifters or replace engine? Why pay $1800 for lifters when.... [Re: bbusbee] #753029 11/03/06 12:39 AM
9
94redrodeo Offline
When I bought my rodeo it had lifter tick then the head gasket blew. I cleaned out everything with brake cleaner and it has not ticked once. I wasn't even worried about the tick I just wanted everything clean so there was no chance of problems form contamination and it cured the tick also,
94 Rodeo 3+3 lift Red)
95.5 Rodeo 1" Body lift Dana 44' front & rear 4.88 gears 35"s 176,000 miles Optima Yellow top InexAir Co2
front winch bumper custom rear bumper, Hella 500's
2004 Silverado duramax
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6107 MB (Peak: 0.6814 MB) Data Comp: Off Server Time: 2026-06-17 11:56:52 UTC
