Carb adjustment
#753090
09/21/06 04:04 AM
Hi guys new here. Been registered a while but never posted. I have a Jeep j-10 with a 77 model 258 I-6. It has the 1 barrel carter yf carb. Recently rebuilt carb but still having problems on angles. Everytime I get the jeep on a wierd angle it starts to flood. It is also running rich at idle. I have recently added a piece of rubber hose to extend the bowl vent tube as was suggested on the fullsized jeep forum to try to prevent flooding. What else can I do to straighten this carb out?
 FrankenJeep J-10 80 body and frame 77 258 engine 79 th400 and bw1339 79 d44's with 3:54gears welded rear 36" Iroks on 15x10 rockcrawlers Soa and shackleflip
Re: Carb adjustment
[Re: Thumpszilla]
#753091
09/21/06 11:36 AM
Have you tried rebuilding it?
Re: Carb adjustment
[Re: JeePete]
#753092
09/21/06 03:09 PM
From looking at your photo one would surmize you take that thing anywhere there is a BUMP to hit.. It is highly likely you have slightly bent the float hangers from these bumps and the bowl level is too deep! This will cause all the problems you describe. Remedy: Take the top off of the carb and observe the float level.. If an old rebuild kit is available (I save many of the old used kits) apply the measuring device to the float to see if it has indeed changed positions. Bend the hanger to acquire the needed level. Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" />
Re: Carb adjustment
[Re: BigJim]
#753093
09/21/06 04:51 PM
Well I do take it to some rough places. Had the front drivers wheel 3 foot in the air this past Sunday. <img src="/forums/images/graemlins/evil.gif" alt="" /> I have rebuilt carb and I think I may order a new float for it. I did not change the float at time of rebuild. I also broke a torsion bar stud on axle coming out of the trail Sunday. Here is a pic of my weekend fun. I would have done better but carb wouldn't allow it kept flooding out on me. ![[Linked Image]](http://i78.photobucket.com/albums/j108/thumpszilla/web%20pics/bumpus/z09-17-06Bumpus070.jpg)
Re: Carb adjustment
[Re: Thumpszilla]
#753094
09/21/06 06:54 PM
A new float will have to be adjusted same as the OLD one... Just open it up and bend the part that touches the needle or the arm itself .. I would bend it to lower the fuel lever bout 1/4 inch.. then see how it fares from that adjustment. Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" />
If you did not get all the balls and springs and weights in the correct places you MAY be sucking extra fuel thru the power parts of the carb..
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.011s) Memory: 0.6053 MB (Peak: 0.6704 MB) Data Comp: Off Server Time: 2026-11-19 05:33:24 UTCValid HTML 5 and Valid CSS
