Re: Torx screw heads stripped [Re: JeePete] #753322 09/30/06 11:38 PM
josephelk Offline
Torx Screws have no Place in America at all. It's kind of like Jeep using on metric bolt on an 89YJ motor mount and a standard bolt on the other motor mount? No rime or reason.
ThatÆs my two cents to the conversation good luck with the rest of your change out, IÆm in the middle of swapping my 4.2 for a 4.0 fuel injected motor so I feel your pain.
Josephelk
89 YJ, 3.5" Black Diamond Lift, 33" tires, 8000lb Warn, 4.0 91 XY engine swap.
Re: Torx screw heads stripped [Re: JeePete] #753323 10/04/06 04:07 AM
N
NedR Offline
Sorry not to respond earlier but was obsessed with a fix and bound and determined. Found my fix, better vice grips. Achieving appropriate torque values is wonderful but if you've ever tried to remove a 10 or later yr. old torx bolt you'd wish for a better design. Many cars were produced long term, restoration and repair depends on the competence of original design. Jeep folds on design. Love the car, but there are faults.
I just fix it, the kid drives.
Re: Torx screw heads stripped [Re: NedR] #753324 10/04/06 03:12 PM
JeePete Offline
I disagree, restoration and repair depends on the competence of the person(s) doing the work. It would be nice if everything was made easy for us wouldn't it? <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Torx screw heads stripped [Re: JeePete] #753325 10/09/06 03:47 AM
N
NedR Offline
Yes it would Pete. And thanks for the advice.
Re: Torx screw heads stripped [Re: NedR] #753326 10/09/06 08:07 AM
jstritec Offline
pete, I think he means the older the jeep, the more likely one is to end up dry humping furniture.
josh
80 CJ-7.
It runs
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.008s) Memory: 0.6096 MB (Peak: 0.6900 MB) Data Comp: Off Server Time: 2026-11-03 12:22:27 UTC
