Throttle body (throttle shaft) seals
#753610
09/23/06 04:05 AM
At 290,000 miles I have a little play in the throttle shaft inside the throttle body. I believe it is the cause of a slight surging at light engine load (1800 rpm, high vacuum condition). Does anyone know if the shaft bushings/seals can be replaced and if so, where I can order new ones? Toyota is very proud of a replacement throttle body.
'96 Taco 4x4 2.7 with 270,000 miles and climbing
Re: Throttle body (throttle shaft) seals
[Re: mollydawg]
#753611
09/26/06 01:31 PM
You only got 290,000 miles out of the throttle shaft seals?? Whatta a hunk of junk!! LOL, gotta love Toyotas, almost 300K and the main complaint is a worn throttle shaft seal. Hate to say it, but you are probably stuck with either the dealership or a junk yard for that part.
John Luttrell 2001 4x4 short cab, 3 inch lift with 33 inch mudders and Powertrax no-slip in the rear
1991 Jeep YJ, 4 inch suspension lift on 33" BFG's
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.5843 MB (Peak: 0.6321 MB) Data Comp: Off Server Time: 2026-07-15 23:38:23 UTCValid HTML 5 and Valid CSS
