Differentials #754426 09/27/06 09:08 PM
Thord Offline OP
Im about the change my differentials, what should I use as a gasket, a gasket, gasket maker, or both? and what should i check for while im in there?
Thanks <img src="/forums/images/graemlins/patriot.gif" alt="" />
86 CJ7, 258, MC2100 Carb, 4" Rough Country lift, 34" Swampers, Jeeperman bumper/tire carrier
Re: Differentials [Re: Thord] #754427 09/27/06 09:16 PM
BigJim Offline
I always use a gasket and NO SEALENT!! Lately the factory has been using pooky on several different gasket places. THIS is one of them.. But a gasket is easily available and I use them instead of the pooky.
Re: Differentials [Re: Thord] #754428 09/27/06 11:10 PM
JeePete Offline
If you have an AMC 20 rear you definitely need a gasket. It's optional on Dana 30's, IÆve done several Dana 30s, 35s and my 44 with just RTV silicone with no leaks, no problems, just try to keep it out of the diff! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Differentials [Re: JeePete] #754429 10/01/06 02:20 PM
superdawg Offline
Pooky! done correctly works just fine, gaskets done incorrectly leak. It is all in the prep and cleaning of surfaces. I've sealed many a amc 20 with just pooky, but the secret there is to let the (fairly large) bead of glop set up for 20 minutes or so before putting the cover on.
(put the pooky on the diff not on the cover)
SD
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5992 MB (Peak: 0.6545 MB) Data Comp: Off Server Time: 2026-05-29 14:45:41 UTC
