Lower Ball Joint Replacement #754787 09/29/06 09:51 PM
Myredyota Offline OP
First off, I did search... The problem that I am having may be caused by the upper ball joint spacers. I finally got the passenger side lower ball joint out-it wasn't pretty. Now there isn't enough room to get the new one in! They are the correct replacements but not enough room. <img src="/forums/images/graemlins/evil.gif" alt="" /> Am I going to have to take the upper one out to get the lower one in?
[color:"blue"]Carey[/color][b]
[b][color:"red"]89 SR5 Extended Cab 4X4 V6
[/color][color:"blue"]Don't forget to pay your taxes......
Millions of illegal aliens are depending on you!!![/color]
Re: Lower Ball Joint Replacement [Re: Myredyota] #754788 09/29/06 11:24 PM
Snowtoy Offline
You shouldn't have to removethe uppers, just lift up on the upper A-arm as you did to install the spacers. After I installed a set of spacers on a project rig, I went back and replaced all of the ball-joints with no problems.
Did you also crank up the t-bars for mor lift? if you did, this may be why you vcan't get enough room.
Re: Lower Ball Joint Replacement [Re: Snowtoy] #754789 09/29/06 11:44 PM
Thanks Snowtoy!
T-Bars are in the stock place. What is the easiest way to lift the upper A-Arm? I am open for any and all suggestions! <img src="/forums/images/graemlins/cyclops.gif" alt="" />
Re: Lower Ball Joint Replacement [Re: Myredyota] #754790 09/30/06 12:00 AM
willzrunna96 Offline
best way would be to disconnect the sway bar and the lower shock mount then the LCA would just fall out
Re: Lower Ball Joint Replacement [Re: willzrunna96] #754791 09/30/06 01:51 AM
Got it! Went out after dinner and had my way with it! Thanks for the tips! <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6047 MB (Peak: 0.6690 MB) Data Comp: Off Server Time: 2026-06-09 10:01:46 UTC
