22r Carburetor Rebuild
#754821
09/29/06 11:41 PM
Anyone had any experience with the rebuild kits from Advanced Auto Parts? Toyota recommends the kit from Napa and it's twice as much. Is it worth it? Thanks.
Re: 22r Carburetor Rebuild
[Re: thxgoon]
#754822
09/30/06 03:08 AM
I just did a rebuild with the AAP rebuild kit. The kit is made by GP Sorensen. I would have went with the NAPA kit but it wasn't in stock anywhere near me.
All told I had no problems with the rebuild and the carb works great. So far..... <img src="/forums/images/graemlins/cheers.gif" alt="" />
"If you can't learn to do something well, learn to enjoy doing it poorly".
85 22RE, 5spd 4Runner project 87 Turbo Truck, Boost Controller, otherwise stock... for now. 86 Turbo 4Runner, Project
[Re: thxgoon]
#754823
09/30/06 04:31 AM
Anyone had any experience with the rebuild kits from Advanced Auto Parts? Toyota recommends the kit from Napa and it's twice as much. Is it worth it? Thanks. YES. If the parts place doesn't ask you for the number off of the metal tag on the carb, run away. They're selling a generic rebuild kit. NAPA and others sell carb specific kits.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 - '84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
[Re: fourwd1]
#754824
09/30/06 03:35 PM
and there are two gaskets for either side of the black "heater" spacer -- you'll need them as well. they may come with the Napa kit, though, didn't with the Advance Auto one I bought all those years ago.
msg - '87 xtracab
[Re: yodta]
#754825
09/30/06 07:15 PM
every 22R carb i've seen has a spacer with the gaskets permanantly glued on. i'm sure you can stack the gaskets a carb rebuild kit on it if the ones that are attached aren't in too bad of shape, but if it's old i'd recommend buying a new one from toyota.
'79 sport 4x4 longbed <img src="/forums/images/graemlins/smile.gif" alt="" /> 20/22R hybrid with EB's OS valves, 268c cam, offy intake, weber 32/36, thorley header, 5 speed swap, 34" LTBs, downey 3" springs, marlin hysteer, 4.88s and locked
'91 4x4 shortbed 22R-E, W56, the dd!
[Re: yodta]
#754826
10/01/06 03:05 AM
and there are two gaskets for either side of the black "heater" spacer -- you'll need them as well. they may come with the Napa kit, though, didn't with the Advance Auto one I bought all those years ago. This one (GP Sorensen) had them though I didn't use them. I just used a micro thin spread of hi temp RTV. By the way I drove the truck with the recently rebuilt carb today in stop and go trafic for an hour or so. Worked great. <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: sindersblue]
#754827
10/03/06 06:55 PM
hey guys just found this site insted of opening a new thred i'll ask my qustion here about my carb , i got 86 pick up 22R ,4 speed,two wheel drive i know it's 4X2 <img src="/forums/images/graemlins/frown.gif" alt="" />but my 4X4 got totaled. she idels high i tryed adjusting the mix,ideal screw and oh yeah i cleand the carb using carb clean , i changed out the fuel flter,air filter,replaced the cap and rotor,new plugs,new wires. after bit of playing around i found the throtal is not closing all the way i can still push on it about a 1cm then she'll idel fine thinking it is a sticky butterfly valve i sprayed some carb cleaner to it to free it up. the engine stols after and there's a vacume leak from there as well. now my qustion to you is that 1. if i were to use the NAPA carb rebulding kit would i get the new seals for the shaft for the butterfly valve. 2. Am i better off with buying a rebult one from NAPA which is about $500 CAD and beaing the student it's bit too much for me right now any info would be grate thanks in advance
[Re: brownguy]
#754828
10/03/06 07:24 PM
Brownguy,
Is the return spring on the carb for the throttle the culprit? Clean up and a little lube over the connections on each side. Give 'er a try.
[Re: Staceman]
#754829
10/03/06 10:15 PM
thanks i'll try that but what i dont get is why is there a vacume leek from the shaft ,resone i'm thinking it's leaking is when i spary carb clean on it the engine quits thats one thing i can get <img src="/forums/images/graemlins/confused.gif" alt="" /> any how i'll try lubing the crap out of it hope fully it'll work thanks brownguy
[Re: brownguy]
#754830
10/04/06 02:36 AM
I'm not sure what "shaft" you are referring to as having a vacum leak. Clarify that and I'll do my best to diagnose it.
X2 on getting the more expensive rebuild kit.
-Scerb
