Re: 22r Carburetor Rebuild
[Re: sindersblue]
#754831
10/04/06 03:16 AM
This one (GP Sorensen) had them though I didn't use them. I just used a micro thin spread of hi temp RTV. the RTV mostly likely won't last. gas will eat right through it and you'll end up with a vacuum leak. if you're going to use a sealant, you need something like Gas-ga-cinch
msg - '87 xtracab
[Re: brownguy]
#754832
10/04/06 05:20 AM
if i were to use the NAPA carb rebulding kit would i get the new seals for the shaft for the butterfly valve. I've never seen seals for the throttle plate shaft in a rebuild kit. I think the shaft is just a machined fit & if it's worn to the point yours seems to be, replacement is probably your best option. Dave
[Re: Scerb]
#754833
10/05/06 01:53 AM
I'm not sure what "shaft" you are referring to as having a vacum leak. Clarify that and I'll do my best to diagnose it.
X2 on getting the more expensive rebuild kit.
-Scerb the shaft i'm talking about is the the throtal link basicly attached to the butterfly valve , iwas told by toyota that the rubber O-ring seal is gone causing a vacume leak (this is from talking to one of the techs)
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.5985 MB (Peak: 0.6682 MB) Data Comp: Off Server Time: 2026-06-09 10:14:07 UTCValid HTML 5 and Valid CSS
