Page 1 of 3 1 2 3
headlight suggestions please...... #754848 09/30/06 03:23 AM
sdsnowman Offline OP
is there a good replacement headlight for a 1 gen 4runner?
mine are sorry yellow blobs on the road and everyone else seems to have these super-extra-white and blue-ish lights now.....
id be willing to pay extra of course....
Re: headlight suggestions please...... [Re: sdsnowman] #754849 09/30/06 04:16 AM
Myredyota Offline
Silver Stars! I love mine (all 3 vehicles)! <img src="/forums/images/graemlins/cheers.gif" alt="" />
[color:"blue"]Carey[/color][b]
[b][color:"red"]89 SR5 Extended Cab 4X4 V6
[/color][color:"blue"]Don't forget to pay your taxes......
Millions of illegal aliens are depending on you!!![/color]
Re: headlight suggestions please...... [Re: sdsnowman] #754850 09/30/06 04:20 AM
fourwd1 Offline
If you upgrade to higher wattage bulbs, plan on upgrading the wiring too. Otherwise you won't get the full effect.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: headlight suggestions please...... [Re: fourwd1] #754851 09/30/06 04:26 AM
no problem- im an electrical contractor.
i have offroad lighting- about 600 watts, but i can only use those in the dunes....
Re: headlight suggestions please...... [Re: sdsnowman] #754852 09/30/06 06:45 AM
stock87 Offline
http://www.rocky-road.com/ipfh4.html
Best price I've found on them. I've got a set, and would gladly pay twice what I did. Makes future bulb changes/upgrades a snap since it converts it to regular H4 Bulbs.
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: headlight suggestions please...... [Re: sdsnowman] #754853 09/30/06 06:34 PM
Buy the upgraded wiring harness from 4crawler.
Then, buy some Hella Vision Plus headlights. Total replacement lights and newer style bulbs.
This combo makes a huge difference over stock and gets you to the newer style bulb connections. You can then carry replacement bulbs as spares instead of having to store / carry a whole new headlight assembly.
Easy upgrade and one of the best dollar for dollar upgrades I have done.
Thanks,
James
Re: headlight suggestions please...... #754854 09/30/06 06:43 PM
sege Offline
If you're looking for the best, go with Cibie. I have the IPF H4 conversion headlamps, 4Crawler wiring harness, and 55/100 Hella bulbs, and while it is a huge improvement over stock, the Cibies are much better. Cost is hard to swallow, but man, I've never seen another halogen headlamp come close to the Cibies. If cost is an issue then the IPF or Hella H4 conversion lamps are good. Just be sure to get the wiring harness, that makes a noticeable difference by itself.
Re: headlight suggestions please...... [Re: sege] #754855 09/30/06 06:54 PM
4Crawler Offline
A lot of the headlight choice comes down to whether you want a DOT spec lamp or not. I run the Hellas, they work fine, much better than stock and they are DOT spec. I've run non-DOT lamps before, they were a bit better, but the worries of getting ticketed for running them was not worth the trouble. I did once get pulled over for a burned out headlight and had to end up eating the cost of the fix-it ticket since I could not get it inspected and signed off since I had the non-DOT lamps (in CA, you need to have headlight tickets inspected and signed off at an official headlight inspection station):
- http://www.4crawler.com/4x4/CheapTricks/Headlights.shtml
The H4s are nice, gives you a wide selection of bulbs and it is easy to carry a spare in the truck. On my VW, I just put in the upgraded harness and found that the existing headlights worked so much better than I opted not to replace them.
Re: headlight suggestions please...... [Re: 4Crawler] #754856 10/01/06 12:24 AM
sege Offline
Yeah, you do run the slim chance of getting ticketed for non-DOT lamps. Guess your choice will depend on what's important to you...
Here's a good read, although I must warn you, *it is from a [email]J@@p[/email] forum* <img src="/forums/images/graemlins/smile.gif" alt="" /> http://www.naxja.com/forum/archive/index.php/t-39615.html
Re: headlight suggestions please...... [Re: sege] #754857 10/01/06 12:47 AM
4Crawler Offline
Like this guy did:
http://www.pirate4x4.com/forum/showthread.php?t=512977
Got pulled over for one small thing then as they went over his rig with a fine tooth comb, found many more items.
I figure I draw enough attention from the authorities, so no need to add anything that I can get nailed for. I try to keep things within the vehicle code, sometimes just barely, but that is all you need.
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.008s) Memory: 0.6401 MB (Peak: 0.7642 MB) Data Comp: Off Server Time: 2026-11-03 17:42:57 UTC
