Page 2 of 3 1 2 3
Re: headlight suggestions please...... [Re: 4Crawler] #754858 10/01/06 05:31 PM
salvo Offline
Dam i know that feeling. the police and MTO boys have had a hard on for me for the last couple of years. Last year they pulled me over a couple of days in a row to inspect my truck. They could never find anything untill the last day when i got a little mouthy with them as they were making me late for work (they kept pulling me over next door to my work) and he finaly gave me a fix it ticket saying i needed flares for my tires as they were sticking out to far.. (they were only past the wheel wells by 3/4") as a truck drove by with at leat 8" of tire past the wheel wells. It was cheeper for me to fix it then loose the days off work to fight it. This year they did the same thing and could only get me on window tinting that has been their for over 5 years and gave me a full inspection ticket that i passed easily... I found out talking to one of the cops later that the MTO boy had it out for me and the only reason the cops pulled me the first time is the design of my bumper makes the truck looks higher than it actually sits and they could see that when i pulled in ... He also told me that the way i welded my skid plate to the bumper clasifyed the skid plate as part of the bumper and i was no ware close to being over because of that. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: headlight suggestions please...... [Re: sdsnowman] #754859 10/01/06 11:50 PM
mnwolftrack Offline
I ordered 4Crawler's kit for my '85 Toyota pickup, and that alone was impressive with the stock headlights. I also ordered Hella Vision Plus H4 housings and used the bulbs that came with them. They helped even more, but I'd have to say the harness was the biggest improvement. My lights don't look dim and yellow on the road anymore.
I liked the setup so much I ordered a second harness to use on my '90 4Runner. This time I'm going to hold off ordering more Hella H4 housings/bulbs until I see the improvement with just the harness alone.
Re: headlight suggestions please...... [Re: Myredyota] #754860 10/02/06 01:11 AM
thefreqofnature Offline
Silver Stars! I love mine (all 3 vehicles)! <img src="/forums/images/graemlins/cheers.gif" alt="" />
x2...I love my Silver Stars!
thefreqofnature
Re: headlight suggestions please...... [Re: sdsnowman] #754861 10/02/06 04:33 AM
OOP'S Offline
Awesome headlights from a vendor that is also a wheeler!!
He also has them in a 7" round.
http://www.roundeyes.com/
7.25" Rectangular Toyota« Conversion Headlamps
RoundeyesÖ introduces a night vision upgrade for the Toyota« owner. Conversion headlamps are designed to replace your OEM issued sealed beam headlights providing you with a much safer nighttime driving experience.
If you have a hard time seeing clearly at night with your stock dim yellow headlights, this upgrade is what you need. RoundeyesÖ conversion headlamps will provide you with a whiter and brighter light output allowing you better vision in the fog, rain, and snow and night time driving conditions.
- 60% brighter than conventional sealed beam headlamps
- GE MegaLight Plus H4 60/55 watt bulbs are replaceable
- Die-cast aluminum housing with a complex multi surface reflector that produces a wider beam pattern
- Heavy duty solid glass lens is durable yet super clear
- Gortex« breather allows heat to escape while keeping moisture out of the lamp assembly
- Lamp assembly can handle off road bulbs up to 130 watts
- Easy drop fit installation with no additional wiring needed
Simply unscrew the headlamp bezel, remove and unplug your old sealed beam headlamp and replace them with these. It's that easy!
DOT approved/SAE certified set includes two lamp assemblies and two bulbs already installed.
The best safety upgrade for you and your family!
We can not remove or exchange the DOT approved bulbs for this kit. Higher wattage bulbs are sold separately and are for off road use only. To be installed by the customer. See "Auxiliary Bulbs" in the main menu.
Fits Toyota« 1st, 2nd and 3rd generation pick-up trucks.
FREE SHIPPING - LIMITED TIME OFFER!
Price: $ 99.00 / pair
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: headlight suggestions please...... [Re: sege] #754862 10/02/06 05:53 AM
stock87 Offline
If you're looking for the best, go with Cibie. I have the IPF H4 conversion headlamps, 4Crawler wiring harness, and 55/100 Hella bulbs, and while it is a huge improvement over stock, the Cibies are much better. Cost is hard to swallow, but man, I've never seen another halogen headlamp come close to the Cibies. If cost is an issue then the IPF or Hella H4 conversion lamps are good. Just be sure to get the wiring harness, that makes a noticeable difference by itself.
Just because I'm curious, why do you say the Cibies are so much better? Light pattern, build quality, something else?
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: headlight suggestions please...... [Re: 4Crawler] #754863 10/02/06 02:27 PM
TexJeff87 Offline
Hey OOPS, I liked your last post in that thread. FWIW, my kid brother is a cop in Denver, and he is not a .... jerk.
If Mad Max had a 4runner...
Re: headlight suggestions please...... [Re: TexJeff87] #754864 10/03/06 06:43 PM
sege Offline
The light pattern is flawless, no hotspots or dim areas. The amount of light they throw to the side of the vehicle is unbelievable. I've run the Hellas, I have IPFs presently, and the Cibies are in a league of their own, IMHO... I haven't seen the Roundeyes headlamp conversion, so I can't comment on those...
Re: headlight suggestions please...... [Re: sege] #754865 10/04/06 02:12 AM
babyhuey Offline
I got the $29 autopal e code h4 headlights off of ebay and I have to say I am impressed.I dont know how long they will last,but beam dispersion is great and lights seem to be of very high quality.I also added 55/110 bulbs and hi beam is like daylight.The light makes a 180 degree sweep,no more dark spots.I am going to upgrade the harness next.Just am glad cops [and state inspectors] arent as watchfull in Virginia.
Re: headlight suggestions please...... [Re: babyhuey] #754866 10/05/06 01:06 AM
AlaskaToy Offline
I have the cibies. I like them a lot. Very sharp low beam cutoff; great for oncomers (not so great for overhead sign illumination). great upper-right illumination for road side signs. E-code lamps (O.K. in AK, but no DOT alignment nipples as req'd for DOT lights - could be an issue in some states)
AJ
93 Toyota, dana 60, 14-bolt
Re: headlight suggestions please...... [Re: AlaskaToy] #754867 10/05/06 01:47 AM
G
Greg_Canada Offline
I've found with my h4 conversion (by bosch) that the low beams are so-so, but the high beams are great.
When i put the lever half way, so both of them are on, the lighting is perfect.
Anyone know how to jerry-rig the high beams so the highs AND lows go on?
89 4Runner
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6440 MB (Peak: 0.7720 MB) Data Comp: Off Server Time: 2026-06-09 21:29:20 UTC
