MOTOR TROUBLES #755069 10/01/06 05:27 PM
I HAVE RECENTLY AQUIRED A 1986 TOYOTA XTRA CAB 4X4 IT ORIGINALLY HAD A CARBURATED 22R BUT WHEN I GOT IT THERE IS NO MOTOR. OBVIOUSLY BEING 18 A 4 CYLINDER ISNT GOING TO DO THE JOB <img src="/forums/images/graemlins/shame.gif" alt="" />. I AM GOING TO PUT A V-8 IN IT BUT HAVE A QUESTION NO ONE SEEMS TO KNOW THE ANSWER TO. DO THEY MAKE AN ADAPTER FOR THE STOCK TOYOTA 5 SPEED TO BOLT UP TO A FORD 351? BECAUSE I HAVE A RUNNING 351 I COULD DROP RIGHT IN. I DO HAVE A CHEVY 350 I COULD USE BUT IT NEEDS ALOT OF WORK. EITHER WAY WHEN THE WORK IS DONE IT WILL BE WORTH IT.
Re: MOTOR TROUBLES #755070 10/01/06 07:43 PM
dentcollector Offline
Sounds like you like power! GOOD LUCK with that stock five speed! I don't see that lasting very long. It can be done, but don't waste your time and money. Get a bigger drivetrain. You'll be better off in the end.
1988 4Runner V-6 Auto, Locked out back, LSD up front, some lift, some tire, and a casual attitude towards body damage.
Re: MOTOR TROUBLES #755071 10/02/06 11:33 PM
IN CASE ANYBODY WAS WONDERING I FOUND OUT THAT THE BELL HOUSING ADAPTER FOR THE FORD 302 WILL ALSO WORK ON THE 351 TO FIT IT TO THE YOTA 5 SPEED, ENGINE MOUNTS ARE STILL A PROBLEM BUT IF I FIND THEM ILL KEEP YOU POSTED!
PHP: 7.4.33 Page Time: 0.008s Queries: 14 (0.006s) Memory: 0.5873 MB (Peak: 0.6414 MB) Data Comp: Off Server Time: 2026-11-03 13:24:20 UTC
