front brake shims
#755190
10/02/06 01:27 AM
anyone know where I can find a set of brake shims for a 2003 Tacoma DC? I just changed my front brakes this weekend and found the shims to be getting pretty worn. I'll probably need to replace them next time around. Thanks.
'03 Tacoma Double Cab, 2.5" Pro Comp Spacer up front, AAL in the Rear.
Re: front brake shims
[Re: mjletts]
#755191
10/02/06 02:31 AM
you must mean the metal anti squeal shims? likey a dealer item only a good set of after market one(pads) will have a shim bonded to the back side of the pads not needing the oem one
[Re: mjletts]
#755192
10/02/06 03:18 AM
I dont reuse them they seem to cause a soft pedal on my trucks . All mine have no shims .
[Re: spannky]
#755193
10/02/06 12:01 PM
The shims came with the new brakes that I got. Just get pads that have the shims included.
98' Toyota Tacoma SR5 Manual Xtra Cab, Slight Lift Maine Rules!
[Re: DentedTacoma]
#755194
10/02/06 05:41 PM
yeah, i went to the dealer and asked about them. They were going charge me $46 for the set, which i thought was a little too high. I figured i could get them after market somewhere else a little cheaper. I've been told that the shims that come bonded to the back of the brake pads aren't as affective as the OEM ones that you lube up. Have you guys had any complaints??
[Re: mjletts]
#755195
10/02/06 10:21 PM
I bought mine at VIP for 20 or 30 something I think. With the shims you took an adhesive protector off of it and then put it on the pads. Havent got them on yet but they will be on later this week hopefully, I will let you know.
[Re: DentedTacoma]
#755196
10/07/06 12:08 AM
Mine came with the Brake Pads when I bought them. Do you think they might be in the box?
[Re: ralleyclimber]
#755197
10/09/06 03:17 PM
Do you think they might be in the box? Nope, not in the box. I went with slightly cheaper front pads that didn't come with the shims. I'm assuming that the more expensive pads come with some sort of replacement shim.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6168 MB (Peak: 0.6979 MB) Data Comp: Off Server Time: 2026-05-29 14:51:49 UTCValid HTML 5 and Valid CSS
