Damn transfer case filler bolt.... #755754 10/04/06 11:39 PM
ciscofreak Offline OP
Ok I exhausted about everything I could try getting the transfer case filler bolt off. The PO stripped the bolt out so I tried getting a pipe wrench on there with heat (from a little propane torch)to no avail. I also tried hammering a wrong sized socket on there and use a breaker bar. That also didnt work. Next I tried the world's largest pliers with no success.....
I know the little propane torch is not putting out much heat so I held it on there all the while tapping the head with a small hammer. I'm about to go pay someone to remove it for me unless you guys have more suggestions.
~Jake
Re: Damn transfer case filler bolt.... [Re: ciscofreak] #755755 10/05/06 01:11 AM
J94_4runner Offline
weld a socket to it. smile
www.celicasupra.com
Re: Damn transfer case filler bolt.... [Re: J94_4runner] #755756 10/05/06 02:37 AM
5
5150 Offline
I once used an air hammer with a wedge type chisel to break a differential filler plug loose. One thing though, you will need to get a new filler plug from the dealer
Re: Damn transfer case filler bolt.... [Re: 5150] #755757 10/05/06 02:52 AM
willzrunna96 Offline
both of the ideas above are the best way ive don them both!
Re: Damn transfer case filler bolt.... [Re: willzrunna96] #755758 10/05/06 03:05 AM
4Crawler Offline
I usually weld an old nut to the head of the plug then use that to remove the old plug. Frequently the heat of welding is all it takes to loosen up the plug. Replace it with one of the socket head plugs.
Re: Damn transfer case filler bolt.... [Re: ciscofreak] #755759 10/05/06 04:11 AM
P
Pluton Offline
You could use a Dremel-type tool to cut a slot into the bolt head, then use a B.F. scewdriver to remove it.
Re: Damn transfer case filler bolt.... [Re: Pluton] #755760 10/05/06 05:01 PM
Thanks for the suggestions. I will pick up an air chisel tonight and have at it!!
Re: Damn transfer case filler bolt.... [Re: ciscofreak] #755761 10/05/06 05:26 PM
krb90 Offline
Also, use the small torch to heat up the transfer case around the bolt, and not necessarily the bolt itself. What will happen (hopefully) is that the heated metal of the transfer case will expand (in micro-millimeters, anyway) around the bolt and remove some of the friction from the threads. That, combined with a hammer and chisel (or air, if you prefer) might do it.
Re: Damn transfer case filler bolt.... [Re: krb90] #755762 10/05/06 06:40 PM
yodta Offline
the welding stuff is the best way if you have a welder.
I didn't, and had a recent similar problem with my transmission fill plug, so I ended up drilling it and using a bolt extractor.
msg - '87 xtracab
hammer and chisel [Re: yodta] #755763 10/05/06 09:00 PM
L
leiniesred Offline
It is OK if you chisel off a chunk or two while you try to back it off. It seals around the edges, usually, you get enough of the edges off and it screws right out. get a new plug while you are out air tool shopping. I too like the socket head plugs.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6303 MB (Peak: 0.7367 MB) Data Comp: Off Server Time: 2026-06-07 04:59:25 UTC
