3.0 Manifold Heat Shield? #755768 10/05/06 02:33 AM
5
5150 Offline OP
While changing the plugs and wires on my 93 V6, I noticed the drivers side manifold heat shield had fallen off the mounting bolts. It is still in the area of the manifold however it is just laying there. The question I have, is there any way to reattach this or should I just get a new one from the stealership?
Re: 3.0 Manifold Heat Shield? [Re: 5150] #755769 10/05/06 03:19 AM
OOP'S Offline
The heat shields on my 90 are part of the exhaust manifold gaskets. You are looking at about 60-70 dollars for the gaskets. Yes you do need the shields, if you do not have them you will cook the plug wires in no time.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: 3.0 Manifold Heat Shield? [Re: 5150] #755770 10/05/06 03:45 PM
Toy4x Offline
I believe there are also some shields that attach to the manifolds, mounted with small studs/nuts. Maybe the studs rusted off, or the nuts backed off (doubtful).
Those shields are not *required* imho
Re: 3.0 Manifold Heat Shield? [Re: Toy4x] #755771 10/05/06 06:53 PM
U
USMCTRD Offline
My driver side one fell off. I found it a couple weeks later at the power line trail. You could reattach them with some bigger washers if the studs/nuts aren't to rusted. I don't think they're that important though.
88 V6 4Runner, 2" 4Crawler body lift, 2" suspension, 32x11.50 Pro Comps
Re: 3.0 Manifold Heat Shield? [Re: 5150] #755772 10/05/06 07:06 PM
P
Paul_H Offline
I'd say use big washers over the existing shield and re-attach it. I just did a head rebuild, and can attest that it's a PITA to reach the nuts/bolts on the shield. If you're rusted out thats and even bigger pita.
'94 extra-cab 3.0 extra slo (auto tranny) original owner. E/B o/s valve heads and no more crossover. More mods to come.
Re: 3.0 Manifold Heat Shield? [Re: Paul_H] #755773 10/05/06 07:16 PM
Rauch_Off_Road Offline
IMHO drivers side deffinately need the shield. The heat coming off that bank is quite high and you have plug wires and intake above it.
(aka suprathepeg, aka Sean)
Re: 3.0 Manifold Heat Shield? [Re: Paul_H] #755774 10/05/06 09:25 PM
5
5150 Offline OP
Yeah the holes where they attach to the manifold seem to have rusted away, I will try the larger washers...thanks
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6177 MB (Peak: 0.6913 MB) Data Comp: Off Server Time: 2026-05-29 17:15:00 UTC
