Help me fill in the blanks... #756302 10/08/06 04:01 PM
Billdo Offline OP
1990 Isuzu Amigo XS w/ 2.6L
Engine: 2.6L 4ZE1
Transmission: ???
Transfer Case: ???
Transfer Case Ratio: 2.2:1
Front Axle: Isuzu 10 Bolt
Rear Axle: Isuzu 12 Bolt
R&P: ?4.56?
Also, would THESE fit into my Amigo?
2000 Chevy Tahoe nothing special. 1990 Isuzu Amigo, 3" lift, 31x10.5x15 BFG All Terrain (Street), 33x12.5x15 (offroad), Pacesetter header, some ATM rash. More mods to come......
Re: Help me fill in the blanks... [Re: Billdo] #756303 10/08/06 07:34 PM
strawmyers Offline
Isuzu Moderator
Your tranny should be the MUA-5, with an integrated transfer case. 4.56 R&P sounds right. Since yours is a '90, the t-case should have a slip-yolk rear output. Those gears are for a fixed-yolk rear output. You can make them work in your t-case; but will need to source parts from a fixed-yolk case as well. There is an old post that outlines what all needs changed over.
[edit] Meh... I'm feeling generous today. HERE is the old thread I was refering to instead of making you search for it. Don't expect this to happen all the time. <img src="/forums/images/graemlins/pfft.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Sean Strawmyer
Re: Help me fill in the blanks... [Re: strawmyers] #756304 10/09/06 05:03 AM
Billdo Offline OP
Ok, but wouldn't it just be easier to just swap a T-Case rather than attempt change out gear sets? I guess I really don't know the likes of a T-Case on an Auto Amigo
Re: Help me fill in the blanks... [Re: Billdo] #756305 10/09/06 06:20 AM
mlclark Offline
Isuzu Moderator
No Amigo had an Automatic transmission and transfer case.
And, since the tranny and x-fer case is integrated (back of one is the front of the other) you can't swap transfer cases.
So...as Sean said, those gears will not fit directly. There are some difference between the two kinds of cases (fixed vs. slip yokes). It can be made to work rather easily and the fixed yoke set up is prefered if you are going to modify your rig. You will need have a driveline made up to fit when you are done, but it is a much better setup than the slip yoke if you are lifted.
If you ever think you are going to a one-piece driveline, (in your case, yours is one-piece, but we are talking one with the slip in the middle, not on the transfer case yoke) the best time to change out the back cover of your transfer case is now, if you are going to do Tera gears. As, if you go with a set of gears for a slip yoke case, you can't just swap over a fixed yoke cover in the future and use the gears.
Michael
PS: If it were me, I would go ahead and make the conversion. It is easy and not that expensive if you shop around for a case. I went the other route and did some fancy work to get a fixed yoke in slip yoke case.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6011 MB (Peak: 0.6579 MB) Data Comp: Off Server Time: 2026-07-12 21:22:27 UTC
