wire harness plug help
#756490
10/09/06 05:43 PM
2.6 engine under the intake runners between #3/#4 runners is a grey 2 wire male plug,where does it go?
It is a black wire/white wire that run into the 16 pin blue connector.I don't rememeber #'s though it may be the 13 and 15 pin?(maybe <img src="/forums/images/graemlins/smile.gif" alt="" />)it was a late night.
Donor intake also has it.I couldn't find ref. to plug,in factory book.
Thankyou.
Bansil
Re: wire harness plug help
[Re: Bansil]
#756491
10/09/06 06:36 PM
Isuzu Moderator
It is most likely the EGR sensor plug for CA Emission trucks.
Michael
[Re: Bansil]
#756492
10/10/06 02:15 AM
IF IT IS THE SAME TYPE OF PLUG THAT PLUGS INTO THE IGN COIL , IT IS AS MICHAEL MENTIONED FOR THE CALIF, EGR TEMP SENSOR , I THINK THERE ARE ONLY TWO PLUGS ON THE ENG THAT ARE THSI TYPE THAT ONE AND THE IGN COIL PLUG BUT IT HAS DIFF COLORED WIRES JERRY
[Re: Bansil]
#756493
10/10/06 02:12 PM
<img src="/forums/images/graemlins/kewl.gif" alt="" /> Thanks guys
Bansil
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6016 MB (Peak: 0.6571 MB) Data Comp: Off Server Time: 2026-06-15 10:38:36 UTCValid HTML 5 and Valid CSS
