emergency brake signal #756705 10/10/06 06:30 PM
fiat850spyder Offline OP
Sometimes when im driving my emergency brake light comes on does anyone know what I can do to stop it?
Re: emergency brake signal [Re: fiat850spyder] #756706 10/10/06 06:32 PM
4Crawler Offline
Check the switch on the e-brake handle, maybe it is sticking closed or loose. Otherwise, if it and the charge light comes on as well, may be alternator brushes:
- http://www.4x4wire.com/toyota/maintenance/alternator_brushes/
Re: emergency brake signal [Re: fiat850spyder] #756707 10/10/06 07:44 PM
BrokeAsAJoke Offline
It will also come on if you're low on brake fluid.
88 Reg Cab 22RE 5spd, Mods: 94 bed, Sunroof, Bucket Seats, PW, PL, AC, Keyless entry, remote start. (Practically a Lexus)
Re: emergency brake signal [Re: BrokeAsAJoke] #756708 10/10/06 08:53 PM
Alright I will check on it. Thank you very much <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: emergency brake signal [Re: BrokeAsAJoke] #756709 10/10/06 08:58 PM
ChrisH Offline
^ <img src="/forums/images/graemlins/kewl.gif" alt="" />
'95 Toyota Pickup DX Xtended Cab ~ Daily Driver
Re: emergency brake signal [Re: ChrisH] #756710 10/10/06 09:17 PM
Scerb Offline
next time it happens push on/wiggle your ebrake handle. If the light goes out you know the switch is sticky.
-Scerb
Re: emergency brake signal [Re: Scerb] #756711 10/11/06 05:39 AM
IceBlueT Offline
another possiblity is maybe its worn out from use. i have found quite a few high milage toyotas (pickups, 4runners, corollas, camrys) that the brake light stays on, but is slightly dimmer than if the E-brake is applied. im not sure if its sticky or if the circuit shorts slightly, but i know that my truck has the same problem. i have noticed that when i apply the brake, the light gets brighter, so im pretty sure mine is just from over use.
formerly 277000_yota
Old enough to know better, but still to damn arrogant to care...
]www.cardomain.com/ride/2614269
'90 'Yota 4X4 (10/31/05-09/10/08 R.I.P)
'98 'Yota t-100. 3.4, 5 sp. 4x4, 2 in. Toytec with BFG A/T 265/70R16s
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6167 MB (Peak: 0.6903 MB) Data Comp: Off Server Time: 2026-07-09 19:58:51 UTC
