Clutch pedal issue #756729 10/10/06 07:09 PM
N
nlexpcoa Offline OP
Recently my clutch pedal has been acting up, with no obvious pattern. While driving i press the clutch in, shift to the next gear, so far so goo, but occasionally the pedal does not come back up off the floor. Sometimes it takes a couple of seconds, but it usally stays on the floor till i pull it back up with my foot. The weird thing is it shifts before and after just fine.
The clutch master cylinder has enough fluid. Is the master cylinder going bad, maybe the slave cylinder? Just air in the line? any help would be appreciated.
Thanks in Advance
Nik
Re: Clutch pedal issue [Re: nlexpcoa] #756730 10/12/06 01:24 AM
dogtoy Offline
yes, probably master cylinder. Pull the sleeve back on your slave, if it is not leeking you probably do not have to replace the slave. This happened to me and I just repaced the master. Do try bleeding first however.
2014 FJ
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5862 MB (Peak: 0.6341 MB) Data Comp: Off Server Time: 2026-06-07 04:20:25 UTC
