4Runner Sitting for Years and Won't Start #757311 10/12/06 07:47 PM
bikedoctor Offline OP
I found a 1990 4Runner that has been sitting for 3-4 years and is claimed not to start. What should I look at prior to purchasing a vehicle that has sat for that long? I'm not very familiar with the V6, but I know the rest of it quite well as I had a 1989 pickup with the 22RE. Would it be safe to try to turn the motor over or should I do something first?
Thanks
Re: 4Runner Sitting for Years and Won't Start [Re: bikedoctor] #757312 10/12/06 11:36 PM
4Crawler Offline
Probably at a minimum pull the spark plugs and give each cylinder a squirt of oil. Then try cranking the engine over w/o the plugs in to see if it'll turn over and if the oil pressure will come up.
Re: 4Runner Sitting for Years and Won't Start [Re: 4Crawler] #757313 10/13/06 12:05 AM
dcg9381 Offline
Drain all the fluids, including the gas.
Shoot oil down into the cylinders, as mentioned above. You might want to try turning it over for a while (no plugs) until you get an indication of oil pressure.
After 3 years, the fuel may be in bad shape...
22REturbo.net
1988 4Runner
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5929 MB (Peak: 0.6460 MB) Data Comp: Off Server Time: 2026-06-07 05:28:13 UTC
