Seatbelt lowering?? #757390 10/13/06 01:46 AM
SolidBlk85 Offline OP
Has anyone lowered the upper seatbelt pivot? My seatbelt rubs the bottom of my neck and my daughter and wife cant even use the upper part of the belt because it goes directly accross their necks.
Re: Seatbelt lowering?? [Re: SolidBlk85] #757391 10/13/06 02:55 AM
Snowtoy Offline
Lowering the pivot point wouldn't be very wise or easy, you would have to reinforce the area where the new pivot point would be located. There are products available that attatch to the belt to lower the shoulder strap for shorter people. You should be able to find them at the dealer or a local parts store.
Re: Seatbelt lowering?? [Re: Snowtoy] #757392 10/13/06 03:19 AM
8
87YotaLac Offline
One of my buddies had one of the coolest ideas on this problem. He used a clip. You know those ones that got real popular and people were using them on their keychains. They allow you to hook your keys to a belt loop, backpack, etc. They make some sort of larger ones and he took it and clipped both sides right below the piece connected to the cab. It keeps the arm strap down on your chest. Works perfect! Its kinda hard to explain in words but hopefully you get the idea. <img src="/forums/images/graemlins/kewl.gif" alt="" />
1985 4runner Bone stock
Re: Seatbelt lowering?? [Re: SolidBlk85] #757393 10/13/06 03:59 AM
OOP'S Offline
I do not know about other models but on my 90 ex-cab there is already a hole set up for that purpose. It is about four inches below the top hole. You have to pull the plastic trim panel off to see it and drill a hole in the trim panel.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Seatbelt lowering?? [Re: OOP'S] #757394 10/13/06 06:00 AM
stock87 Offline
Same on my '87. There's even a dimple in the plastic trim that corresponds to the prethreaded hole.
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: Seatbelt lowering?? [Re: stock87] #757395 10/13/06 04:05 PM
Just took a look and found the dimple. I'll cut it out today and give it a shot. Thanks!
Re: Seatbelt lowering?? [Re: SolidBlk85] #757396 10/13/06 09:00 PM
PERFECT!!!
Thanks folks
Re: Seatbelt lowering?? [Re: SolidBlk85] #757397 10/14/06 01:19 AM
ACES_HI Offline
Us long haired folks, like down to the middle of our backs are following this thread very closely. Yes it does indeed suck to have the seat belts constantly pulling at my hair! <img src="/forums/images/graemlins/frown.gif" alt="" /> No I will not cut it and I encourage others to chime in on their solutions! <img src="/forums/images/graemlins/kewl.gif" alt="" />
'04 Taco x-cab 3RZ FE stock (daily driver)
'90 x-cab 22RE stock
'82 Hilux 6" lift (ACES HI)
'82 2-Hiluxs' Rally Edition (parts)
'81 Hilux 3" lift (parts/restore)
Re: Seatbelt lowering?? [Re: ACES_HI] #757398 10/14/06 01:30 AM
trythis Offline
cut your mullet. <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6267 MB (Peak: 0.7303 MB) Data Comp: Off Server Time: 2026-06-10 01:24:57 UTC
