engine sputtering, shut off
#757404
10/13/06 02:28 AM
hi i have a 97 jeep wrangler 2.5 l 4 cylinder, the problem is i run the car for bout 3 miles and it doesnt run right it starts sputttering to the point where its misfiring and wont drive-its not the sparkplugs, the throttle position sensor, or plug wires cuz they r all new idk wut else to fix ive run out of ideas does anyone have any info on how to fix this?
Re: engine sputtering, shut off
[Re: xtnsiper0]
#757405
10/13/06 02:35 AM
when does it stop sputtering? How do you get home? Big Jim <img src="/forums/images/graemlins/pfft.gif" alt="" />
[Re: BigJim]
#757406
10/13/06 02:46 AM
we have to liek pull over and stop for a lil and soemtimes it fixes and soemtimes it dont it like sputters and barely moves
we just take it out cuz we r trying to fix it
[Re: xtnsiper0]
#757407
10/13/06 05:18 AM
go to autozone or another parts store and see if they have a scanner to pull codes. im thinking it may be the o2 sensor,and since you are there you can get the needed part
[Re: cuervo25]
#757408
10/14/06 02:47 AM
weve taken it to autozone and got codes read-it says there was something wrong with the throttle sensor which i mentioned above and we put a new one on n it still does it,we unplugged all 02 sensors to try it without them and it still did it too
[Re: xtnsiper0]
#757409
10/15/06 05:14 AM
AHT Have u looked at the fuel filter, air filter, cap, rotor...With the past vehicle I drove it did exactly what your stating, because of moisture in the cap rotor. Buy new ones and spray with wd40 wipe and air dry thouroughly. Replace dirty air cleaner and fuel filter. Also change your gas cap. Just some thought from past experiences and less expensive then a stop at dealer.
[Re: cjensen]
#757410
10/15/06 11:13 PM
ok, rotor cap is dry and clean rotor is fine gas cap is fine, my dad ran it up to a higher temperature in the grage idling,it didnt spuuter or do it, we drove it 2 miles came to a stop sign n it kicked in, anymore ideas anyone?
[Re: xtnsiper0]
#757411
10/16/06 06:30 AM
Any more ideas? Sure. EGR & PCV
[Re: xtnsiper0]
#757412
10/16/06 12:02 PM
I experienced something like you about a year ago. We tested and replaced alsmost every sensor but nothing did help. At last we exchanged the engine computer and since that time the engine runs fine. I found the computer on EBay and payed $90 for it. Good Luck.
