Clutch release cylinder leaking...easy replacement? #757491 10/13/06 05:21 AM
nuclear3579 Offline OP
(95 Tacoma, 14X,000 miles.)
There's a leak at the boot on the slave cylinder. It doesn't leak all the time, but yesterday my g/f lost most of her fluid. Not enough to put air in master cyl, thankfully.
Lines are good, leak is definitely comming from the rubber boot. I assume the slave is leaking the fluid right through to the other side with the boot.
Any experience? Easy replacement? Would you bother rebuilding the cylinder?
thanks.
Too close for missiles, I'm switching to guns...
'97 4Runner...SR5, 4cyl (3RZ), 5spd, 4wd, no rust, excellent shape.
Re: Clutch release cylinder leaking...easy replacement? [Re: nuclear3579] #757492 10/13/06 07:17 AM
kewlynx Offline
The replacement cylinders don't cost that much; just make sure you've got enough DOT 3 on hand for a good bleed, and adjust the clutch pedal height/play when you're done. Article is in the maintenance section. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Not hard to replace; more of a PITA than anything.
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5884 MB (Peak: 0.6363 MB) Data Comp: Off Server Time: 2026-06-17 12:56:09 UTC
