Page 1 of 3 1 2 3
4-runners vs. pickup. #757532 10/13/06 01:34 PM
9
92daily Offline OP
So I sold my second toyota truck and am looking to get a 4-runner... 90-95 model. Most of the ones I'm finding are autos. I've always had manual transmission trucks. Are the auto trannys in these 4-runners worth a crap off-road and on?? Does the 3.0 have enough ass to move a set of 33's on stock gears??
I appreciate your input and I look forward to having a 4 door off-roader/daily driver.
I'm between toyotas right now... 3rd Gen 4-runner soon.
Re: 4-runners vs. pickup. [Re: 92daily] #757533 10/13/06 04:41 PM
DirtyHarry Offline
Toyota Moderator
No. The suck a lot of power and use a unique transfer case that makes it harder to modify them for off-road prowess relative to four cylinder Toyotas. This is also true of the manual used behind the V6, but it is stronger, gives you more control, and doesn't suck as much power. Also less expensive to rebuild if you get a high mileage vehicle.
No. Personally I think that these are one of the worst platforms you can start with. They are heavy, underpowered, IFS, and lots of glass and sheetmetal. I would look for a 96+ with the 3.4L, just my opinion though.
Re: 4-runners vs. pickup. [Re: DirtyHarry] #757534 10/13/06 05:09 PM
krb90 Offline
Agree 100%. I have had two friends with 4-runners, ('92 and '94) both 3.0 automatics and my '90 ext cab pickup 3.0 manual will blister both of them on and off road, hands down. Not even close.
Re: 4-runners vs. pickup. [Re: krb90] #757535 10/13/06 05:20 PM
Rauch_Off_Road Offline
Get a gen 1 runner. They are the poop. I'd like to see someone use a gen 1 body on a 2wd frame with an SAS. The 3.0 aint as bad as people think, its just usualy found in gen 2 runners with autos. Can't beat the simplicity of the 22re though.
(aka suprathepeg, aka Sean)
Re: 4-runners vs. pickup. [Re: Rauch_Off_Road] #757536 10/13/06 07:42 PM
bkg Offline
I disagree with Harry... Sorry, bud. <img src="/forums/images/graemlins/nana.gif" alt="" />
Brian K. Gallus
Re: 4-runners vs. pickup. [Re: bkg] #757537 10/13/06 09:16 PM
G
Greg_Canada Offline
I can easily beat my buddies 3.0 auto 91' pickup with 28's and 4.56's with my 3.0 5spd 89 4runner with 33x12.5's and 4.10's...
a 2nd gen 3.0 with a 5spd should be fine, a bit slow, but fine.
Im planning a 3.4 swap myself, i need power to pass over 60mph....
But, a 96 would be a nice platform, or get a 98 with a 5spd and e-locker!
89 4Runner
Re: 4-runners vs. pickup. [Re: bkg] #757538 10/13/06 09:59 PM
DirtyHarry Offline
Toyota Moderator
What part did you disagree with Brian? About the auto sucking power or the 2nd Gen 4Runners being tubby and underpowered? I value your opinion so I am curious.
Re: 4-runners vs. pickup. [Re: DirtyHarry] #757539 10/13/06 10:11 PM
TexJeff87 Offline
Somebody is doing t-case mods for the auto's now...is it Inchworm?
Anyhow, I don't have a 3.0, and from what I've read here I don't think I'd want one. My 22re is in a first gen, it wrassles with being powerful enough and that's with an EB cam for torque and proper gears. I can't imagine a 22re in a second gen with 33's and an auto.
Be patient and find a first gen runner. The removable top cool factor is all the impetus you need. And as long as you take care of it, that 22re'll run forever.
But I'm biased....
If Mad Max had a 4runner...
Re: 4-runners vs. pickup. [Re: TexJeff87] #757540 10/13/06 10:14 PM
willzrunna96 Offline
they make a dual transfer case for the auto only if you have a A340F tranny. I do beleive that my new 96 runner is more capable than my 91 pickup
Re: 4-runners vs. pickup. [Re: willzrunna96] #757541 10/14/06 01:23 AM
My 88 4Runner with the 3.0 and 5 speed drives great with 32's and stock gears. I would never give up the 3.0 for a 22RE unless it had a turbo. The 2nd gen 4Runners are underpowered with either engine and the auto does suck the power even more. But my old 87 4Runner 22RE turbo with 32's and the automatic was still the quickest Toyota I've had by far.
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6394 MB (Peak: 0.7637 MB) Data Comp: Off Server Time: 2026-10-30 10:20:40 UTC
