okay, I'm going up and need some help #757559 10/13/06 03:10 PM
W
white_boy Offline OP
Alright, I am finally ready to modify by bone stock 96' t-100 5 speed. A friend gave me some 18" mickey thompson wheels (10" wide, 4.5" backspace) with 325/60/18 (33x13.5)ATZ tires. Yeah I know, great friend huh?! Anyway, I know I need to go up to put them on the truck, but how much? Is a 2 inch body lift enough or do I need a 4" suspension lift, or both? Any recommendations on body or suspension lift manufactures? I have been reading posts and surfing the site for several years and thanks to all for all the great advice!
1997 T100, 3.4 extracab, 5 speed, 4x4,
4" ProComp Lift, ProComp SS Skidplate
Fiberglass sprayed in bed liner
Re: okay, I'm going up and need some help [Re: white_boy] #757560 10/13/06 05:29 PM
Brew Offline
Well a 285/75-16 with OEM 16x7 alloys (+15mm offset or 4 & 5/8"/4.625" back spacing) will result in the tire mildly rubbing the idler arm. 285mm = ~11.2" width (25.4mm to an inch) and you have 325s. 285s on a 16x8 w/4" b.s. will fit with tight tolerences on a 2" bodylift and some minor fenderwell modifications. ErikB and others did 33x12.5s on 15x8s w/3.75" bs and only rubbed the back of the front fender well.
I'd say you'd need 3/4" - 1" wheel spacers and 3" - 4" of lift to fit without use of a sawzall. But even that may be way off using 10" wide wheels. There was somebody running 15x10s previously and may have been a 3" body lift but will leave that for you to search.
TRD_Justin?
Good Luck <img src="/forums/images/graemlins/kewl.gif" alt="" /> Brew
98 T100 SR5 4x4 3.4L auto, TRD Goodies, Bilsteins, engine/TC skids, 2" body/d.train lifts, F/R ARBs, 4.56 R&Ps, Aisin hubs, 255/85R16 Dunlop Rover RVXTs (street), 16x7 +8mm offset wheels, custom bumpers, Warn M8000, Master-pull synth. line
Re: okay, I'm going up and need some help [Re: white_boy] #757561 10/13/06 10:45 PM
ErikB Offline
Toyota Moderator
The wheels may be big enough to keep the tire sidewall away from the UCA, but I can't say for sure. Just have to mount one up and see. If they clear, a 2" BL should get the body to clear. With spacers, you may also need to do some firewall hammering too. If you don't want to do that, more lift will be needed.
http://home.4x4wire.com/erik
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5935 MB (Peak: 0.6482 MB) Data Comp: Off Server Time: 2026-06-07 04:32:15 UTC
