EFI to carb swapp #757562 10/13/06 03:13 PM
L
Lil_Jon Offline OP
I am putting a 22r(carbrated) out of a 1983 in a 1991 yota with a 22re(EFI) and Im not sure how to hook up the engine wire harness
Re: EFI to carb swapp [Re: Lil_Jon] #757563 10/13/06 03:18 PM
DRTDEVL Offline
The only answer is DON'T hook it up like that!
Get either a different engine, or use all your old EFI stuff... Intake, exhaust, and sensors. You will have to tap out a hole on the driver's side of the block for the knock sensor.
There is no advantage to going carb... Less power, less mileage, and more adjustments to make.
Re: EFI to carb swapp [Re: DRTDEVL] #757564 10/13/06 03:23 PM
bkg Offline
I have to agree with this. Also, that 83 is a different block w/ a taller deck hight,, different timing chain, etc.
Brian K. Gallus
Re: EFI to carb swapp [Re: bkg] #757565 10/14/06 06:59 AM
L
Lil_Jon Offline OP
Understandable I will use the EFI so where is this hole I have to tap? And what emmisions can I remove?
Re: EFI to carb swapp [Re: Lil_Jon] #757566 10/14/06 11:56 AM
DRTDEVL Offline
Don't remove any emissions stuff... It does nothing but hurt you in the long run.
The hole will be somewhere on the passenger's side of the block. You should se it about 1/4 to 1/2 way up from the bottom, not in the original knock sensor location, though.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6029 MB (Peak: 0.6676 MB) Data Comp: Off Server Time: 2026-11-02 14:21:33 UTC
