Leaky Intake Manifold #757585 10/13/06 05:21 PM
sled207 Offline OP
Hey Folks
Does anybody have the torque values for the intake manifold on a 90 Montero 3L. I put a new intake gasket on because the old one was leaking, but I can't get the new one to seal. Thanks for the help.
Re: Leaky Intake Manifold [Re: sled207] #757586 10/13/06 06:07 PM
P
pcc Offline
168 in-lbs
Where are you in SW Alaska? I lived in Eagle River for 5 years.
Re: Leaky Intake Manifold [Re: pcc] #757587 10/13/06 06:28 PM
sled207 Offline OP
Thanks for the values. Hope this stops the leaks.
I live in Dillingham. Been here 7 yrs. Grew up in northern SC. What part NC are you from?
Re: Leaky Intake Manifold [Re: sled207] #757588 10/13/06 07:56 PM
P
pcc Offline
Not from here, just living here for now. Chapel Hill, that northern liberal enclave surrounded by Southern Reconstructionists. <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Leaky Intake Manifold [Re: pcc] #757589 10/13/06 08:48 PM
sled207 Offline OP
After seeing those values; I may have over torqued the intake. The new gasket helped the leak, but didn't stop it. Maybe I cracked the new gasket and will have the job to do again.
Re: Leaky Intake Manifold [Re: sled207] #757590 10/14/06 12:04 AM
FrankR Offline
Clean the flanges well with acetone or laquer thinner. Spray 2 coats of Copper Spray-a-Gasket on the flange faces and both sides of the MLS gaskets. Reinstall and torque to spec.
Frank
Re: Leaky Intake Manifold [Re: FrankR] #757591 10/14/06 03:02 AM
Have the heads or block been milled? That would make the manifold sit higher in relationship to the heads, and may bind the manifold on the studs which are on the bias. If you mill either, you should mill the manifold flanges by the same amount divided by the SQRT(2), or 1.414 for a 90* motor, and by 2 for a 60* vee motor.
Re: Leaky Intake Manifold [Re: fasteddy] #757592 10/16/06 01:42 PM
dadrab Offline
Upon reassembly, progressively tighten the stud nuts in a circular pattern, much like you would head bolts.
That'll apply the pressure evenly.
with awesome audio.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6211 MB (Peak: 0.6987 MB) Data Comp: Off Server Time: 2026-06-23 18:45:43 UTC
