American Bolt in the Bell Housing? 1988 Trooper II
#757631
10/13/06 11:19 PM
Hi, I recently rebuilt my 1988 Trooper II engine, and I am now hooking the transmission back to the engine. There is one bolt hole that doesn't seem to want to thread in. This bolt is the ONLY one that threads into the transmission from the engine side, all others go directly into the engine block. I am wondering, could this be some strange american thread? I tried going to the junkyard and threading one of my bolts into a similar transmission there, and it did the same thing, it just doesnt feel right. Any help would be very appreciated.
1988 Trooper II in the works.
Re: American Bolt in the Bell Housing? 1988 Trooper II
[Re: AndyR]
#757632
10/13/06 11:47 PM
I know some engines use pilot dowels and there is often a hole but no threads. Did you take hardware out of the hole or did you just notice it was missing?
disregard that you are talking 2.6 motor right? I thought GM.
CHRIS 98 Amigo, 92 Pup
[Re: AndyR]
#757633
10/13/06 11:59 PM
If it's the one I think you are talking about, it's a coarse thread bolt, unlike all the others, which are fine thread. If I'm not mistaken, it's on of the starter bolts.
1995 Trooper LS auto 3.2 DOHC /w SOHC intake 1989 Trooper 2.6 auto 1989 I-Mark RS DOHC 1.6 1991 Stylus XS DOHC 1.8
[Re: AndyR]
#757634
10/14/06 01:50 AM
IF IT IS THE LOWER BOLT ON THE STARTER IT IS A 10 MM BY 1.5 MM THREAD PITCH, THE SAME AS THE STUD ON THE TOP OF THE STARTER WHERE IT THREADS INTO THE TRANNY CASE ONLY TWO ON THE ENG OR TRANS ATTACHMENT BOLTS THAT ARE 1.5, JERRY
[Re: JLEMOND]
#757635
10/14/06 05:30 AM
Awesome guys, thanks, I was just out there trying to fix it and I found that bolt. A little bit of a small distinction if you ask me, but I guess next time i'll sort the bolts out better. Thanks again, that really helped.
