Re: Oil Presure and cold Idle speed problems on Montero SR 1995. [Re: NathanC] #758215 10/17/06 05:57 PM
Mad_Scientist Offline
That's cool Nathan and about the same price as the stealer sender <img src="/forums/images/graemlins/kewl.gif" alt="" />. So does your gauge move rapidly with changes in engine speed/load? I wonder if you could use the original gauge and just replace the sender with one that gives you 'real' readings.
Re: Oil Presure and cold Idle speed problems on Montero SR 1995. [Re: Mad_Scientist] #758216 10/17/06 06:10 PM
NathanC Offline
It does move pretty rapid with engine speed. I'm not sure if you could use the original gauge because I would assume that the sender/gauge combo would need to be a match set.
I only had an idiot light to begin with, and found out the hard way that the light will only work if the wire is hooked up to the sender <img src="/forums/images/graemlins/shiner.gif" alt="" />.
An engine rebuild later, I vowed to have a real gauge. <img src="/forums/images/graemlins/kewl.gif" alt="" />
'06 Dakota QC 4.7 6sp 4x4
'88 Mighty Max
'77 KZ1000 fun old bike
Re: Oil Presure and cold Idle speed problems on Montero SR 1995. [Re: NathanC] #758217 10/17/06 06:28 PM
Not always. Different car, but same problem and as you can see from this just a sender can be used sometimes. I'm not saying that there's anything wrong with what you did Nathan, it's just interesting. I have a '92 Miata (<img src="/forums/images/graemlins/ignore.gif" alt="" />) which has a real gauge and that thing jumps up and down WITH the tach <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Oil Presure and cold Idle speed problems on Montero SR 1995. [Re: Mad_Scientist] #758218 10/17/06 07:04 PM
NathanC Offline
I think that article proves my point. The sender only gave that guy a moving gauge. It wasn't calibrated to any specific value. He had to modify the circuit with a resistor to improve it.
That's the reason why you can't necessarily mix and match any sender and gauge that you want off the shelf.
'88 Mighty Max
Re: Oil Presure and cold Idle speed problems on Montero SR 1995. [Re: NathanC] #758219 10/17/06 07:24 PM
I agree. I was just interested in the idea of having a more accurate reading while retaining the stock gauge. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Oil Presure and cold Idle speed problems on Montero SR 1995. [Re: arm755] #758220 10/18/06 12:19 AM
Houston Offline
I'd have to check my FSM about your fast idle set-up on a 3.5 liter engine. The way the older 3.0's work like mine is this, there is a fast idle valve at the bottom of the throttle housing. Bolts to the bottom of the throttle actually. It's coolant temp controlled if I'm not mistaken. <img src="/forums/images/graemlins/notooth.gif" alt="" /> The valve when cold should be open to allow more air to bypass, which gives you a higher cold idle . Then, as the coolant heats up from the engine running, it slowly closes, and your idle drops down. The stepper motor, which is just above this valve takes over idle duties at all other times. Make sure your engine coolant temp sensor is working as well. For a 3.0 liter 12 valve engine, it plays a huge role in keeping the stepper motor control by the engine ecu accurate. Mitsu's number 1 check when using the FSM for idle instability is to check the NTC or coolant temp sensor. Usually if it's this bad you'll set an intermittent Check Engine light as it moves in and out of specs. For a 3.0 liter, you get fault code 21, probably a different code on the 3.5 liter engine like you have. I'll check the FSM tonight if someone else doesn't have more/better 3.5 liter info for you.
You may only need a gentle cleaning of the stepper motor and the section of the throttle that it sits in.
'92 SR Montero, Green, with 31" Yokohama Geolandar A/T Plus Tires, Mitsu factory fog light kit, on-board air compressor,Sony Radio and 10 disc changer. 213K and counting.....
Stock & Happy otherwise
Re: Oil Presure and cold Idle speed problems on Montero SR 1995. [Re: Houston] #758221 10/18/06 06:22 PM
A
arm755 Offline OP
Thank you very much for your replay Houston. Last time I changed the spark-plugs I noticed that all the plenum was full of a black layer in the inside like Burned oil and also the throttle body so maybe this valve maid be stacked from that dirt. I will checked it this weekend. Tank you very much.
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.009s) Memory: 0.6250 MB (Peak: 0.7364 MB) Data Comp: Off Server Time: 2026-11-16 08:54:46 UTC
