Can't get 22RE to start after rebuild #758369 10/16/06 09:46 PM
V
Volcom Offline OP
Finished the rebuild last week, got the engine into my 84 4Runner that I'm swapping to EFI. I tried for 30-45 mintues on Saturday, cranking it to get it started and no go. I tried again yesterday with my dad holding the flapper door for the AFM open and still no dice. We left the truck in the garage and he came out later and there was a huge puddle of gas on the floor. The charcoal canister was completely full of gas and running over the top. I cracked the gas line at the cold start injector and had fuel pressure at the injector. We're kinda out of ideas. We had spark. Coil was working.
Any ideas? We still need to set the engine timing but was hoping to get it running to time it. Also, we took the spark plugs out and spun the motor over to build oil pressure, we never saw any pressure on the autometer gauge? Is that a problem??
Is cranking the motor over for 30-45 mintues bad?
Re: Can't get 22RE to start after rebuild [Re: Volcom] #758370 10/16/06 09:48 PM
bigStinger Offline
I saw a slight pressure reading on mine when cranking w/out plugs. It's hard to see, it doesn't build up much pressure, but it definitely did it. One time I put the pump back on without the spring and it wouldn't hold pressure, but if you rebuilt yours you would probably not be as inempt mechanic as I.
For Sale or Trade
33" AT Winston Wheelers. Nearly New.
all stock except for 4.88s...
Re: Can't get 22RE to start after rebuild [Re: bigStinger] #758371 10/16/06 11:22 PM
G
GOI87 Offline
WELL, I kinda had the samething happen to me. I have an 87 22re that wouldn't start after my rebuild. My culprit was the injectors. They were clogged up. Here's my thread on my problem.
http://www.4x4wire.com/forums/showf...&o=&fpart=1&vc=1
Give it a read and see what you come up with <img src="/forums/images/graemlins/kewl.gif" alt="" />
GOI
PS. Are you sure your not 180 degress off?
87 Toyota 4Runner-RV Head, Custom Grind Cam, Doug Thorley Header, Keith Black Pistions, 2 1/4" Magnaflow cat, Dynomax Exhaust
2003 Toyota Matrix XRS-Injen CAI
Re: Can't get 22RE to start after rebuild [Re: Volcom] #758372 10/17/06 02:43 AM
I don't know that I can help with the starting problem but it sure sounds like you have the vent and return lines switched at the gas tank.
You have an FSM right? You should check the TPS and the AFM and check for pulse at the injectors. Also make sure the ground wires in the EFI harness are grounded.
Re: Can't get 22RE to start after rebuild [Re: GOI87] #758373 10/17/06 04:22 PM
V
Volcom Offline OP
Fuel injectors where sent off, tested, and cleaned. All 4 came back in good shape.
I'm not sure what you mean by 180 degrees off? Engine timing?
Re: Can't get 22RE to start after rebuild #758374 10/17/06 04:27 PM
V
Volcom Offline OP
I think you're right about the switch up on the vent and return lines.
I will check for pulses at the injectors and check the AFM and TPS. I believe I got all the ground wires connected.
I have the FSM. Everybody always talks about how good they are. I can't stand the thing <img src="/forums/images/graemlins/smile.gif" alt="" />. It takes forever to find torque specs and some of the directions are not always the clearest.
Thanks for the help!
Re: Can't get 22RE to start after rebuild [Re: Volcom] #758375 10/17/06 08:31 PM
dcg9381 Offline
Yes, he means engine timing.. You should be about to fire your #1 cyliner.. Look under the distrbutor cap.
The process should be to verify that you've got fuel and spark.. then we can help debug.
22REturbo.net
1988 4Runner
Re: Can't get 22RE to start after rebuild [Re: dcg9381] #758376 10/18/06 12:13 AM
Vonka Offline
Mine couldnt start because I didnt connect one of the hoses on the bottom of the throttle body and check for all of your ground connections to the block and EFI.
88 4x4 22re
86 2wd 1-ton 22re
91 2wd 22re
Re: Can't get 22RE to start after rebuild [Re: Vonka] #758377 10/18/06 03:10 PM
V
Volcom Offline OP
I figured it out last night. One connector going back to the fuel pump wasn't fully connected <img src="/forums/images/graemlins/zombie.gif" alt="" /> Makes sense because I could never hear the fuel pump kick on so we started looking for power back there and never found it.
But, that's now the least of my worries at this point. See thread Other thread talking about my new problem
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.010s) Memory: 0.6294 MB (Peak: 0.7333 MB) Data Comp: Off Server Time: 2026-11-18 11:58:46 UTC
