drain plug? #758437 10/17/06 12:30 AM
I searched but couldnt find anything. How do you drain the coolant on my 89 2.6 trooper. I can see the little thing to turn to release the coolant but i dont know where it comes out at. It seems like the front skid plate is in the way. Really cant see stuff that well because of the skid plate. Didnt really want to make a mess and open the bottom hose.
Re: drain plug? #758438 10/17/06 01:30 AM
Z
zKnightWhoSaysNi Offline
It will come out the drain plug, just not a nice steady stream. Remove the skid plate, it's just a few bolts. then you can drain without making too much of a mess with a wide drain pan.
'99 Trooper, 912's
'89 Trooper RS, 2.6
Re: drain plug? [Re: zKnightWhoSaysNi] #758439 10/17/06 01:33 AM
strawmyers Offline
Isuzu Moderator
If you leave the skid plate on, it comes down in 1000 little streams. Consider yourself warned. <img src="/forums/images/graemlins/zombie.gif" alt="" />
Sean Strawmyer
Re: drain plug? [Re: strawmyers] #758440 10/17/06 01:43 AM
darn ok, i didnt want to remove the skid plate. But oh well. Thanks guys!
Re: drain plug? #758441 10/17/06 03:50 AM
litnin Offline
You don't have to take the skid plate off.
Take a piece of cardboard box and cut it about 10-12 inches
long and about 5 inches wide.
Fold it in a U shape and make a channel out of it.
Slide it up under th drain spout and put a pan underneath
that is capable of holding 3 gallons or so.
Use the cardboard channel to direct the anit-freeze over
the skid plate and in to drain pan.
Been doing it this way for a long time.
the
1995 Trooper LS auto 3.2 DOHC /w SOHC intake
1989 Trooper 2.6 auto
1989 I-Mark RS DOHC 1.6
1991 Stylus XS DOHC 1.8
Re: drain plug? [Re: litnin] #758442 10/17/06 04:24 AM
mlclark Offline
Isuzu Moderator
You guys are waaaaayyyyy over thinking this.
Go to the hardware store. Get some 1/2" or so plastic tubing. 12-24" will do. Crack the valve and put the tubing on. Then open the whole thing up. Nary a drop is spilt. No mess, no soggy cardboard, no coolant in your hair.
Michael
Re: drain plug? [Re: mlclark] #758443 10/17/06 07:54 AM
haha allright. Well i did a combo of those things . Thanks guys
Re: drain plug? [Re: mlclark] #758444 10/17/06 12:25 PM
litnin Offline
Put the tubing on what?
There isn't a drain nippled on these trucks and
on mine, a 1/2" tube wouldn't fit over the ears on the
plastic screw valve. The valve comes out half way and dangles.
I've never spilt a drop or got it in my hair doing it with the cardboard.
Re: drain plug? [Re: litnin] #758445 10/17/06 11:49 PM
mlclark Offline
Isuzu Moderator
Ooooh, you have one of those petcocks where it is flat with the ears.
On mine, there is a small round extension beyond the ears that is about 1/2" in dia. Hose fits on there nice...
Michael
Re: drain plug? [Re: mlclark] #758446 10/18/06 01:54 AM
litnin Offline
Cool... Haven't seen the extension on them.
The ears are nice until a few years get on them and they
get brittle.... then break off when you try to remove the plug. <img src="/forums/images/graemlins/scared.gif" alt="" />
PHP: 7.4.33 Page Time: 0.082s Queries: 16 (0.078s) Memory: 0.6364 MB (Peak: 0.7384 MB) Data Comp: Off Server Time: 2026-10-24 04:20:30 UTC
