How do you search for a exhaust leak? #758922 10/18/06 03:10 AM
i just failed inspection for a leak in my exhaust
i have a 98 rodeo ls with 70k miles
anyone have tips to search out the leak?
also..the sound is much deeper now..
any advise be great
thanks
Re: How do you search for a exhaust leak? #758923 10/18/06 03:19 AM
bob large Offline
I just feel for it. I keep the car running then hold my hand by the pipe/ muffler / cat, exc.
If the exhaust is cold you can use water and dish soap mix, from a spray bottle. It will make little bubbles from the leaking area when you spray it on. Works well when youÆre looking for air leaks on an air tank too.
Steve C
Re: How do you search for a exhaust leak? #758924 10/18/06 04:00 AM
trooperbc Offline
it depends where it is. did they say?
for example, you can crawl under there under the exhaust while your helper plugs the exhaust pipe end with a rag.
if everything is all tight, it'll usually load up real quick, if there is a leak there won't be much restriction and you often can *hear* where the leak is -- follow your ears.
1992 sohc trooper 3.2l v6 automatic . . . as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Re: How do you search for a exhaust leak? [Re: trooperbc] #758925 10/18/06 04:24 AM
Chef Offline
You can also see a grayish colored area around the leaks. Sometimes very faint but there nontheless. Exhaust tubing around here turns brown right away so that gray coloring stands out. Check rusted areas on muffler, especially around crimps.
91 T, 2.8 A/T, Weld Wheels, 33 A/Ts, 3? Calmini lift & stabilizer, OME leafs & shocks, ARB lockers F&R, 5.38s F&R, Superwinch Hubs, full roof rack, brush guard, One Bad rear bumper, Hella fog/driving lights
Re: How do you search for a exhaust leak? #758926 10/18/06 04:50 PM
Pyro4117 Offline
In cold, damp weather (may not happen where some of you live) you can also look under the vehicle when it is first run for the day and usually see condensation at the leak site.
Jay
1991 Trooper - DEAD! 2.8 V6, 5 spd, 4WD, HD clutch, 2.25" exhaust, EPROM Chip, KC/Hella, Aisin hubs, Rancho 9000X's, Panasonic/Infinity/Alpine
My Pics
Re: How do you search for a exhaust leak? #758927 10/18/06 09:11 PM
HCMP Offline
Start off checking the places that are prone to leakage:
where two flanges meet (gaskets)
flex pipe
bottom of the muffler
in my case where the exhaust pipe meets the muffler is cracking around the weld
Re: How do you search for a exhaust leak? #758928 10/19/06 04:18 PM
F
Fujisawa_Rob Offline
any advise be great
thanks
Use a piece of tubing (rigid, like brake line) attached to a rubber hose. Stick hose in ear. Listen for whistling noises at joints (collector gaskets, where manifolds join to downpipes, etc).
2000 Mitsubishi Montero Endeavor, "Katsumi", 138k
1993 Toyota Tercel, backup vehicle, 93k
1989 Isuzu Trooper, "Beniko", R.I.P. at 233k
My 'Genuine Isuzu Parts' decals - for sale
Re: How do you search for a exhaust leak? [Re: Fujisawa_Rob] #758929 10/19/06 04:37 PM
HCMP Offline
The Y pipe went on my 99 amigo two years ago. I remember a few other folks talking about the same thing in a relative time frame.
I don't remember what it was about the pipe, just that I replaced it. <img src="/forums/images/graemlins/drunk.gif" alt="" />
Edit:
Now I remember... My driveshaft let go on and killed it.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6209 MB (Peak: 0.7143 MB) Data Comp: Off Server Time: 2026-05-29 16:20:21 UTC
