Opinions on offset rear axle for SAS #758983 10/18/06 01:58 PM
Starchild Offline OP
There is a set of axles advertiesd locally from a J-20. I'm waiting to hear back from the seller, but I thought it might be a good candidate for a future SAS. According to my research, it should be a 3/4 ton, with a D44 front, D60 rear. I don't know the year, but it looks like if the front is Passenger drop, then the rear will be a SF D60 with about a 6" offset to the passenger side. I've seen comments that if you're not swapping it into a jeep with a short rear drive shaft, then the offset rear is workable.
If the price is right, I might consider these, but I just wanted to get some opinions of the offset rear in my Passport. I've got a pretty long rear shaft with my shorter drivetrain.
Thoughts?
<img src="/forums/images/graemlins/cheers.gif" alt="" />Andre
"SERENITY NOW!"
Re: Opinions on offset rear axle for SAS [Re: Starchild] #758984 10/18/06 02:08 PM
RobG Offline
IMO, don't bother. you don't want to deal with a quadratec axle if you don't have to. I don't see you running the offset diff in your Isuzu as is, especially if you plan on keeping highway driving. its significantly offset, without a tcase swap/relocation, this will cause driveline geometry issues big time. yes, you can retube them to center the diff, but again, a lot more work than you want when rear axle choices are so plentiful.
and btw, some J20's come with D60 FF (not SF) too. Though, I've heard this is a light duty version and the tube thickness isn't what you'd find compared to the same axle out of a big van/truck.
-Rob
Re: Opinions on offset rear axle for SAS [Re: RobG] #758985 10/18/06 02:26 PM
Thanks Rob. That's pretty much what I figured.
As far as I can tell, they switched to the FF D60 after '75, when they also switched to a drivers side drop.
If the guy is willing, I might just take the front axle, which I understand is pretty standard D44 stuff.
Thanks,
"SERENITY NOW!"
Re: Opinions on offset rear axle for SAS [Re: Starchild] #758986 10/18/06 03:02 PM
RobG Offline
yea, the front axle is good. the heavier J-trucks even came with 8-lug D44's and some had flat top knuckles. The width is around 65" iirc, so its a little wider than your typically waggy D44 that is more common.
-Rob
Re: Opinions on offset rear axle for SAS [Re: RobG] #758987 10/18/06 07:58 PM
Smiley Offline
I went down this road a little while back, when a friend was parting out an old J-20...
Rob got me to see the light about how much of a PITA it would be to try to use that offset D-60
(Thanks Rob! <img src="/forums/images/graemlins/kewl.gif" alt="" /> )
Anyway, I got a passenger-side-drop, full-width, 3/4 ton, 8 lug Dana 44 out of the deal - although, IIRC, I'm pretty sure that it measures 67".
<img src="/forums/images/graemlins/smile.gif" alt="" />
Six Isuzus, so far... still have three of them.
Re: Opinions on offset rear axle for SAS [Re: Smiley] #758988 10/18/06 08:32 PM
My info says 67" as well <img src="/forums/images/graemlins/nana.gif" alt="" />
It's all beside the point in this case. I talked to the guy today, and it's a centered diff, D60FF, BUT, the front is drivers drop <img src="/forums/images/graemlins/frown.gif" alt="" />
The search continues...
"SERENITY NOW!"
Re: Opinions on offset rear axle for SAS [Re: Starchild] #758989 10/18/06 08:48 PM
Bigpoppax2 Offline
I just saw some Unimog axles in the trader paper today. You want the number? <img src="/forums/images/graemlins/evil.gif" alt="" />
Joe
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6174 MB (Peak: 0.7102 MB) Data Comp: Off Server Time: 2026-07-10 10:28:10 UTC
