Tire size for a GenII
#759124
10/18/06 09:41 PM
Hey guys, first post, I just bought a 92 Montero 4x4 base model. I will crank the torsion bars up to level it out, and do a 1 inch bodylift on it - what tire can I fit on there with the stock 15 inch wheels? Will I be able to fit a 32 with out rubbing? Thanks!
Re: Tire size for a GenII
[Re: Robb]
#759125
10/19/06 03:41 AM
Hello Robb and welcome to the 'Wire. You should be able to fit a 32x11.50 tire on factory 15x7's without modification. I know many of the folks with mid-90's SR's have run 33x12.50's on a stock (or only slightly cranked) rig. I cranked the torsion bars only an inch or so and I run 33x12.50's. I'm not sure about the rim width or offset on a base 1992, so if they're only 6" wide you may want to consider a tire narrower than 11.50. There are a variety of opinions on the best tire width vs. rim width combination. Personally, I think a 15x7 and 32x11.50 would be fine. My 33's are on 15x8's. I'm sure others will post and give you their opinion.
1997 Montero SR
<a href="www.georgiaoverland.com" target="_blank">www.georgiaoverland.com</a>
[Re: DavidG]
#759126
10/19/06 03:47 AM
Thanks <img src="/forums/images/graemlins/kewl.gif" alt="" />. The tires stock on here are tiny 235/70/15 = 28inch tire, looking at this truck and doing a few half a$$ measurements, it looks like I would be lucky to fit a 31 inch tire on there. <img src="/forums/images/graemlins/confused.gif" alt="" /> Here is a pic of the truck in question, I want to use the wheels on it, that I assume are stock
[Re: Robb]
#759127
10/19/06 04:00 AM
Yes, tiny tires but nice looking truck! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Welcome to the wire!
?_________ |_|_|\____\___ l-----[O]≡≡≡≡[O] ()_)()_)-----)_) Stay the Trail!
[Re: CapnCrunch]
#759128
10/19/06 04:29 AM
Rob, Here's my '92, with no lift, and stock wheels. You can see that there's all kinds of room left with 31s. I'm buying 33s this time around. ![[Linked Image]](http://pics.montypics.com/stony-man/2006-04-13/1144953025_mvc_371f.jpg)
- '92 LWB V6 3.0 5 sp 33x10.5 BFG M/Ts & Bouncy seat - '95 LWB V6 3.0 Auto (Scrapped) - '05 Montero Limited. Bone stock <img src="/forums/images/graemlins/frown.gif" alt="" />
[Re: stony-man]
#759129
10/19/06 04:38 AM
Stony, are your stock rims 15x6?
1997 Montero SR
[Re: DavidG]
#759130
10/19/06 04:58 AM
That looks great, did you crank the torsion bars in the front?
[Re: Robb]
#759131
10/19/06 05:40 AM
Man, I'm embarrassed to say that I don't KNOW what width those wheels are. I had long thought they were 7". But I saw an auction on Ebay for a set like mine and they said they were 6". Mine are the same white steelies, I just painted mine black 6 years ago. I'm only going to get 10.5 width tires, so I shouldn't have to worry about it. Very slight crank on the Tbars...less than an inch. I'm going to crank them further after I put on the 33s, and get by like that until I can "schedule" a 2" body lift.
[Re: stony-man]
#759132
10/19/06 08:04 PM
Isn't the correct stock size tire 235 75 15? The 75 would make it a bit larger diameter over the 70 size tire. No?
'90 Montero XLS (Sold, sadly) '95 Montero LS 160k '03 Montero Limited 30k
[Re: Winston]
#759133
10/19/06 08:38 PM
Isn't the correct stock size tire 235 75 15? The 75 would make it a bit larger diameter over the 70 size tire. No? Yes, that's the stock size = 29" tire
