rear end noise?? #759354 10/19/06 03:02 PM
8
87YotaLac Offline OP
On my 85 4runner I'm hearing a noise coming from the rear end. It sounds kinda like the noise big knobby tires make while going down the road. The only problem is I don't have knobby tires and it only does it when I hit the gas. When I let off the gas it quits making the sound.
1985 4runner Bone stock
Re: rear end noise?? [Re: 87YotaLac] #759355 10/19/06 04:18 PM
krb90 Offline
How loud is the noise?
Are there any driveline vibrations with it?
Is it coming from the middle or from the wheels?
Can you crawl under, try to rotate the driveshaft at the axle and feel any slack?
Re: rear end noise?? [Re: krb90] #759356 10/19/06 07:13 PM
8
The noise is loud enough to where I can hear it over the radio. Not extremely loud just annoying. About the same amount of noise as knobby tires on pavement. Of course the faster I go the louder the noise. It doesn't start until I get up to about 25-30mph. It seems to drive smooth just noisy. As soon as it quits raining I'll check for the slack.
Re: rear end noise?? [Re: 87YotaLac] #759357 10/19/06 07:47 PM
Scerb Offline
also check your diff fluid and u-joints..
-Scerb
Re: rear end noise?? [Re: Scerb] #759358 10/19/06 11:26 PM
G
GOI87 Offline
I second U-Joints
87 Toyota 4Runner-RV Head, Custom Grind Cam, Doug Thorley Header, Keith Black Pistions, 2 1/4" Magnaflow cat, Dynomax Exhaust
2003 Toyota Matrix XRS-Injen CAI
Re: rear end noise?? [Re: GOI87] #759359 10/20/06 01:14 AM
bigStinger Offline
3rd on u joints. how many miles on your diff? I just had to replace mine because it was growling... kind of like what you describe. Are you losing any fluid back there?
I would check u-joints, then jack it up and check your wheel bearings. Also make sure your drums are okay. I mean, start with the easier things first.
For Sale or Trade
33" AT Winston Wheelers. Nearly New.
all stock except for 4.88s...
Re: rear end noise?? [Re: bigStinger] #759360 10/20/06 01:20 AM
OOP'S Offline
Are the backing plates wet with gear oil, if so it is axle bearings.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: rear end noise?? [Re: 87YotaLac] #759361 10/20/06 06:19 PM
I'm going to vote for bearings. Those are the same symptoms I had on my Chevy and my Ford. Both cases had bearing issues. Good news is it won't be that expensive.
I'm not saying it isn't a u-joint, it just sounds more like something bad in the diff itself.
Good luck,
James
Re: rear end noise?? #759362 10/20/06 07:58 PM
krb90 Offline
If the driveshaft feels solid (no slack or play), there isn't any gear oil leaking at the bearings (it usually slings out all over the inside of your tire), and there is the proper amount of oil in the diff housing, then maybe you can jack it up, start it, put it into gear and see if you can isolate the sound while the wheels are spinning in the air. Mind you, this is potentially one of those "hey, watch this" moves, so be very careful. Or, if you have somebody you don't like much, you can have them hang off the rear bumper while you are driving down the road. Just kidding, but seriously, this is one of those noises that only happens while you drive and can be hard to figure out, until it gets a lot worse, or breaks altogether. Just try to isolate where the sound is coming from exactly, and diagnose from there.
Re: rear end noise?? [Re: krb90] #759363 10/20/06 10:25 PM
bkg Offline
Pull it apart. Don't guess. could be something simple like wheel bearings, could be something bad as my rear diff...
http://forum.ih8mud.com/showthread.php?t=112977
Brian K. Gallus
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.008s) Memory: 0.6365 MB (Peak: 0.7437 MB) Data Comp: Off Server Time: 2026-07-16 08:54:07 UTC
