Re: rear end noise?? [Re: bkg] #759364 10/20/06 10:44 PM
krb90 Offline
That is what it sounds like to me, especially if the sound is coming from the diff housing, which is not good. But, I would make sure that is where the sound is really coming from before I tear anything apart. Keep hope alive.....maybe it's something not so bad.
Re: rear end noise?? [Re: krb90] #759365 10/22/06 12:46 AM
8
87YotaLac Offline OP
I crawled up underneath it and the drive shaft is tight! No play what so ever! What next? I guess I will try to jack this thing up!
1985 4runner Bone stock
Re: rear end noise?? [Re: 87YotaLac] #759366 10/22/06 05:48 AM
Brian894X4 Offline
I'd bet for sure it's carrier diff bearings.
This is very common on higher mileage Toyotas that haven't had the diff oil changed on a regular basis. If you're hearing a howling sound from the rear diff, that's very likely it, IMO.
Drain the diff fluid. It's probably pretty mucky or at least silvery and stinks like heck.
If I remember correctly, mine only made the noise under a load. When I let off the gas, it went away. When I finally pulled out the old diff and took apart after replacing it with a new unit, the carrier bearings fell apart in my hands.
Now that you checked the driveline, next thing is drain the diff fluid and examine it.
Re: rear end noise?? [Re: Brian894X4] #759367 10/25/06 02:01 PM
8
*update* The problem is the diff., I drained the oil and it was totally silver. After putting new oil in, it did quiten down a little. BTW, what causes the oil to turn silver? Is it shavings over time?
Re: rear end noise?? [Re: 87YotaLac] #759368 10/25/06 03:49 PM
sdsnowman Offline
my 86 4runner did the exact same thing- let me guess- whooooooooooooooooooo...... until you let off the gas right?
on mine it was the pinion shaft bearing. it was a result of using oversized shackles (to cure the saggy rearend).
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.009s) Memory: 0.6107 MB (Peak: 0.6918 MB) Data Comp: Off Server Time: 2026-07-15 15:41:31 UTC
