94' 4Bummer - Blown head gasket
#759468
10/20/06 12:06 AM
Greetings from Santa Cruz,
Our 94' 4Runner (Black Betty) has blown a head gasket <img src="/forums/images/graemlins/zombie.gif" alt="" />
Oh well...with 170K+ miles on this engine, should I replace rather than repair? I won't be doing the work, so no great savings on the repair. Otherwise, what brand of head gasket is best? Felco? or the Toyota gasket, or are they the same? Any brands to avoid?
Thanks much, Hugh <img src="/forums/images/graemlins/mrt.gif" alt="" />
94' 4Runner SR5 3.0L, 4X4, 5-speed, 200K
01' Sienna XLE, 105K, auto everything...
91' Ford F-250, 7.3 liter IDI diesel, 5-speed, 170K
Re: 94' 4Bummer - Blown head gasket
[Re: Hugh]
#759469
10/20/06 11:46 PM
Well, prices for rebuilt engines are a bit too much for me to shell out at this time.
Advice I found on 4x4wire, don't spend more than the car is worth. Looks like the head gasket repair will be good enough, along with a new knock sensor, timing belt, possible water pump. Any thing else to replace while the motor is out?
Thanks much,
Hugh
[Re: Hugh]
#759470
10/21/06 02:07 PM
How about camshaft seals. Ofcourse new head bolts if you didn't already know. You really don't have to remove the engine to do this work. I just did one two weeks ago and left the engine in the truck. Less work. I used a kit from ebay. http://cgi.ebay.com/ebaymotors/TOYO...yZ33617QQihZ003QQitemZ130037743121QQrdZ1
1995 4Runner Limited V6 3.4 Liter 5 Speed 4x4 1995 4Runner V6 Auto 2WD
[Re: Kutter]
#759471
10/23/06 08:23 AM
The fleabay reference made is also someone we in the Yota section here buy from directly as well; Ted's a good guy. www.engnbldr.comWe also have several articles in the maintenance section you can check out to see what other stuff you can take care of while the engine is down; via the Toyota section in the header above. We also have a '93 FSM sticky'd in the early trucks section for your perusal. Remember to change your oil and filter; might be contaminated with coolant.
[Re: kewlynx]
#759472
10/26/06 12:11 AM
update: engine block is warped and requires tear down. So, I'm forced with going for a rebuilt and I can't afford this while paying for one child in college.
I feel the need to cut my loses and go in another direction...maybe tow it home and think about it.
--Hugh
[Re: Hugh]
#759473
11/01/06 12:29 AM
Update 10/31/06: I dropped off the motor today at the machine shop. With a special jig made for this 3.0L, they are able to deck the block without removing the pistons, rods and crank. No other shop could do this work without a complete tear down. The motor should be ready tomorrow <img src="/forums/images/graemlins/cheers.gif" alt="" />
--Hugh
