best way to joining 4 AWG wire together
#759501
10/20/06 03:07 AM
i need to extend my battery cables to accept reverse terminals, do they make a butt connector sytle wire crimp for this. i was thinking of getting some copper pipe and smashing the to ends together anyone have any ideas or suggestions?
91 pickup 5.29's US GEAR.35x 12.50 trxus m/t.5 speed swap- SOLD! 96 4Runna limited-toytec/OME lift,diff drop Nitto 285/75/16 Elocked=butter 07 FJ cruiser 3" DR coilovers 285/75/16 nitto TG. allpro sliders
Re: best way to joining 4 AWG wire together
[Re: willzrunna96]
#759502
10/20/06 03:22 AM
solder and shrink wrap. you might want to look at car stereo amp wire connectors, they have all kinds of switch / fuse / distribution blocks for big wires like that.
[Re: willzrunna96]
#759503
10/20/06 05:33 PM
Yes, they do make butt connectors for large cable; the boat store(West Marine,etc) will have nice silver plated ones. Shrink tube is separate.
[Re: Pluton]
#759504
10/20/06 06:23 PM
I found some splicing connectors at the local hardware store. It used screws to hold the wires in place, then put heat shrink over the connector for insulation. Have also used copper tube or fittings that just over the wire and then soldered the wire in place. Also, check out the local welding supply place, they also carry connectors for heavy gauge wire.
[Re: 4Crawler]
#759505
10/20/06 07:04 PM
Check one vote for solder and shrink wrap <img src="/forums/images/graemlins/kewl.gif" alt="" />
-1986 TOYOTA 22R ZUK coil rear Torqued T-Bars Marlin HD clutch
AZTTORA #492 TLCA member
"I hear there's rumors on the Internets that we're going to have a draft." --George W. Bush
[Re: 4WD22R]
#759506
10/21/06 02:29 AM
Watch for one of your local electric utility trucks and go talk to the fellows. They should have the connectors and the big crimpers to do the job. Best to have the cables with you so you can talk them into doing it for you right there. There should be self sealing ones that they use underground if you can get them to produce them.
Randy
1995 V6 SR5 5 speed 4X4 - 4Runner - dark blue
[Re: willzrunna96]
#759507
10/22/06 03:29 PM
I tried soldering 6 AWG to make a new (+) cable from the battery to the fuse box, but there was zero chance of that happening. I have a decent craftsman soldering iron and it would not heat even a 6 AWG anywhere near close enough to hot. I ended up going to an electrical supply store and bought ring type crimp connectors. They also have the screw kind that 4crawler was talking about.
[Re: mnwolftrack]
#759508
10/22/06 07:07 PM
Yes, soldering larger cable means using a torch as opposed to an iron.
[Re: willzrunna96]
#759509
10/22/06 10:21 PM
Toyota Moderator
While I have soldered large gauge cables before I had access to the proper tools below, I was never enamoured with the results.. Expensive proper tools.. Crimpers are around $300.00+ <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> and do a great job as shown on the 1/0 cable below.. ![[Linked Image]](http://personalpages.bellsouth.net/d/a/dandeman/photos/cable_crimpers.jpg) A less expensive way to do it is using the devices below.... Marine Supply stores are a good place to get heavy duty electrical parts when you can't buy them direct from commercial supplier (i.e. wholesaler) sources.. ANCOR Heavy Duty Lug Crimper.. I checked a number of places for price.. $55.00 for the crimper shown below is a good price.... http://www.shipstore.com/SS/HTML/ANC/ANC701010.htmlBUTT Connectors for 4gauge wire.... http://www.shipstore.com/SS/HTML/ANC/ANC252150.html
2000 4Runner,V6,Auto,31's, Sliders, Skids, On-Board Air, Air Shocks Related Interests: Welding, Ham Radio, Road Tripping (Blue Highways), High End Video/Audio Systems
[Re: Dandeman]
#759510
10/23/06 03:38 AM
wow what a respons i got so far. thank you all for helping me out i think im gonna attack this some time this week!
another question...if i do decide just to run all new wires can i use an audio amp style wire?
