22r that can rev #759622 10/21/06 12:13 AM
TinyTruck Offline OP
Alright heres the deal: I can not keep a stock 22r togather at all (blown 2 in 3months) so I figure I need to build one up that can sustain a rev without coming apart. I am thinking a 22r that is bored .40 over with forged rods and dome top pistons aught to be plenty substantial. For the top end I plan on a ported and polished head running oversized valves (how big?) with HD springs (how burly?) I know I am gonna need some sort of rocker work but I dont know what. And for a cam I want one that will make power from 1k rpms all the way up to 6.5k rpms.
Also is their any way to put a rev limiter on one of these pigs?
1988 YOAT "Stumpy"
-Lock-Right -Fabtech spare tire carrier
-3in PA BL -Custom Flatbed
-32x11.5 cooper mall-terrains <BALD>
Re: 22r that can rev [Re: TinyTruck] #759623 10/21/06 12:38 AM
stock87 Offline
PM ArbitraryNotion. He's got an EB special with some super duper valve springs that he routinely takes to 7+ as far as I know. As for the rev limiter, you generally have to go to an aftermarket ignition that has spark cut at a given RPM.
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: 22r that can rev [Re: stock87] #759624 10/21/06 01:33 AM
willzrunna96 Offline
not really sure about what your trying to do but a 22r wont make any power above 4500 tpms unless yuo worked the hell out of it. an aftermarket ignition system such as MSD box will have an option to add a rev limiter
Re: 22r that can rev [Re: willzrunna96] #759625 10/21/06 02:25 AM
Thanks, this is the type of info that I am after as well because my knoledge of these motors is lacking
1988 YOAT "Stumpy"
Re: 22r that can rev [Re: willzrunna96] #759626 10/21/06 02:27 AM
subliminaltrips Offline
you might want to have the rotating assembly ballanced.
and dude at 7k your simply not doing anything but floating valves. the only way id take a 22r that hight is if it was an lc engineering pro race engine. and that would be on accident. that kind of rpms is not good for these engines and is not nescessary and is really pointless. but its your money. if you want power look in to the lexus v8 swap. or a supra swap.
Re: 22r that can rev [Re: TinyTruck] #759627 10/21/06 08:10 AM
G
Greg_Canada Offline
89 4Runner
Re: 22r that can rev [Re: subliminaltrips] #759628 10/21/06 03:44 PM
Stevie Offline
Wanna rev? Try this:
http://www.4x4wire.com/cgi-bin/gall...t_Stevens.jpg&img=60&tt=
<img src="/forums/images/graemlins/evil.gif" alt="" />
'80 4X4 Longbed
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6179 MB (Peak: 0.7084 MB) Data Comp: Off Server Time: 2026-06-07 04:22:49 UTC
